06-12-2020, 09:41 PM | #1 |
Is it as easy as just swapping out rotors
I picked up a 67 C10. The truck has already been converted to four wheel disc brakes, but the problem is it’s still six lug. I would like to convert it to five lug. Is it as easy as just swapping out the rotors?
06-12-2020, 10:15 PM | #2 |
Re: Is it as easy as just swapping out rotors
On the front end yes rear end will need new axles or have the holes welded up and machine out 5 bolt pattern
06-12-2020, 10:28 PM | #3 |
I think the fronts needs new spindles at least.
06-12-2020, 10:35 PM | #4 |
It has the CPP disc brake kit with 2 inch drop spindles. Does that make a difference?
06-12-2020, 10:36 PM | #5 |
I have a couple sets of 71-72 spindles, calipers and rotors but I was hoping to keep the drop spindles.
06-12-2020, 10:51 PM | #6 |
If it were me, I would call CPP and ask if their 6 and 5 lug disk kits use the same spindle - rather than make a decision based on our guesses.
06-12-2020, 10:54 PM | #7 |
That’s what I’ll end up doing I guess. Sometimes it’s harder to get anybody on the line at CPP than get answers from the forum.
06-12-2020, 11:01 PM | #8 |
06-12-2020, 11:07 PM | #9 |
67-72 parts collector,…
Should be a straight swap to 5-lug rotors if you have the CPP spindles on there now.
06-15-2020, 04:37 PM | #10 |
OK thanks. I can’t seem to get anybody on the phone at CPP. All I can do is leave a message.
