Old 06-17-2020, 02:56 PM   #1
shortboxin
shortboxin's Avatar
5.3 C10 Swap Idle Issue
Thanks for all of the help with the A/C pressures. Now with that behind me, I need to resolve the second major issue on this truck, the idle.
It's more of an issue when the engine is first started, doesn't have to be a cold engine. When it's idling without stalling, the truck's lucky to be at 570RPMs.
Things I've checked and/or tried:
Replaced IAC - went back to OEM since problem wasn't resolved
Cleaned MAF sensor
Replaced O2 sensors with Bosch specific fit
Sprayed around intake with starting fluid to determine if there might be a vacuum leak - no change at all in RPM and I doused it with 2/3 of a can.
Double checked PCM C1 blue pins 20 and 57 to constant +12V
Verified coil pack side and plug side are all fully seated for all 8 wires
Checked fuel pressure: KOEO = 54PSI, KOER = 44PSI at idle and 54PSI when throttled moderately. Also disconnected vacuum line while running and it came up to 53PSI from from 44PSI.
I realize that the fuel pressure is low, but I don't know if my gauge is accurate. Tried to rent one from Autozone, but all 4 stores near me were out of stock.
BTW, no codes in the computer per my OBD II scanner, but the tuner also just told me that it won't throw P0300 misfire codes, he believes because the fuel tank level isn't being sent to the PCM.
Youtube videos of how it sounds:
https://www.youtube.com/watch?v=Z9LVq95IQTA
https://youtu.be/BPxKjJetD0Q
Last edited by shortboxin; 06-21-2020 at 05:12 PM. Reason: Added comment about no codes in PCM and other T/S items I've followed up on.
shortboxin is offline   Reply With Quote
Old 06-18-2020, 10:02 AM   #2
skyphix
Re: 5.3 C10 Swap Idle Issue
A little bit more info is needed;
What PCM are you using and has it been tuned/modified at all?
Edited because I realized the DBC stuff doesn't have an easily adjustable idle speed screw and its controlled by the IAC. There is a TORX screw below the TB but you also have to do a TPS reset. If you didn't change that during the swap, its probably more related to build up than adjustment. Clearly I have more experience with DBW.
Another stupid question is, did you verify that all of the spark plug wires are firmly snapped into the coil packs? Two clicks total for factory wires.
Do you have a check engine light or OBD2 reader that you could scan for any codes?
I am finding a ton of info on dirty DBC Throttle bodies causing the throttle blades to stick. Idle speed between 500-600 is very normal, but below that isn't. Have you tried using brake cleaner to clean out any gunk in and around the throttle blade, including pushing it open with your finger and cleaning any residue around the blade and hinge areas?
Eric
1980 C10 SWB
2003 Chevy Suburban 2500 LT
skyphix is offline   Reply With Quote
Old 06-18-2020, 04:27 PM   #3
shortboxin
shortboxin's Avatar
Thanks for the reply!
The PCM is from a 2002 Chevy Tahoe with DBC. I don't know specifics as to model number if that's what your asking. It has been modified, but pretty much only to remove anti-theft and rear O2s. I had wondered if the guy that tweaked it may have made a mistake?
Everything stayed stock.
I can double check this, but I'm pretty confident on this.
No CEL on the truck yet, but no codes in the scanner. Sorry, should've mentioned this up front.
I have not done anything more than a quick clean. Thing is that it never feels like it's sticking when I press the gas. Additionally, the truck sounds like it's on the verge of stalling when it's at 550-600RPM.
Old 06-18-2020, 06:06 PM   #4
skyphix
Its a little weird that it sounds on the verge of stalling at that RPM with a totally stock engine. Does it ever high idle when its cold? Or does it keep trying to find low idle?
Have you checked your fuel pressure at all? Whats the fuel system setup?
I'd give the TB a more thorough cleaning. Not all I found felt sticking - but they all seemed to benefit from a good cleaning. Both of the 5.3's I have here are DBW so I dont have a DBC throttle body here to look at.
Removing VATs and the rear O2's (disabling secondary O2 bank) really shouldn't cause this issue - even without O2's hooked up it should idle (mine did, just really rough.)
Do you have any exhaust leaks BEFORE the O2 sensors? What is the exhaust setup? Its hard to tell from the video but it does sound like theres quite a bit of exhaust leak. Might just be the video.
What is your intake tract setup? Are there any modifications to the engine? Specifically, cam?
In this video, this is my truck at "cold" idle (air temp was around 80) - around 750-800rpm.
https://www.youtube.com/watch?v=kUoSWj7fvXo
At the beginning of this video, you can hear what hot idle is, fluctuating a bit between 525 and 550. I still need to do some fine tuning to this tune (this is a 6.0 tune thats been adjusted for my displacement and injectors, done by PSI, but I'll be picking up HPTuners and fine tuning it.)
https://www.youtube.com/watch?v=nWyB34SdS9U
Yours sounds like its running rough through the whole RPM range that was in the video you posted... I know you checked for vacuum leaks, but if the cam it stock, it does sound like a vacuum leak. All the ports are plugged off on the TOP of the intake, correct?
Eric
1980 C10 SWB
Old 06-19-2020, 12:57 AM   #5
layinrocker65
layinrocker65's Avatar
seems like a fuel pressure issue to me. Throw a gauge on it and see where it’s at.
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 06-19-2020, 09:29 AM   #6
shortboxin
shortboxin's Avatar
As for wanting to stall, if it's at 550RPM, it's okay except it will drop lower to the 350-400RPM range and then stall from there. If driving, then coming to a stop or slowing for a turn, it may just stall under the additional load. When you say cold, I will assume you mean engine cold. To that, I don't believe it ever high idles at all.
I should probably also mention that I assume it is a stock cam. I bought the engine used with 125K and just put new gaskets, seals, and externals like sensors and water pump on it.
I have not checked fuel pressure. I have a hard time believing that the pressure could be low enough to cause an idle problem, yet accelerate with no issues. I stomp on it and it responds very well. Am I wrong in that assumption?
Running a stock pickup and tank from an 87 R10 and using a 96-97 Chevy P/U pump.
Will do.
This is what he was supposed to do. I'm not 100% sure that's what was done... he asked a number of things, all answers below. He's been doing these for years, so I anticipate that he's just got files he downloads quickly and that's it. Maybe he did the wrong one?
PCM Part #12200411
Drive by cable TB
5.3 from 2004 Silverado (based on dished piston)
2532_ _ _ _ fuel injectors (VIN Z)
2002 return style fuel rail
Case grounded O2s
I can get better video maybe Sunday from outside the truck so it'll be easier to hear. I'm running S10 swap shorty headers with true dual exhaust, no crossover pipe, with side exit. I'm not running cats and I have Flowmaster "glass packs". In my opinion, I don't think I have any exhaust leaks, but I had to drill out 5 of the header bolts and one of them had some minor thread damage, so I didn't want to torque it a lot for fear of stripping it out.
Intake and throttle body is stock 2002 Tahoe. As far as I know, the engine was stock. I bought it used from a friend of the guy that owned the truck (he went to prison). As for cam, I can't be 100% sure.
In my opinion, I don't believe I'm having any issues with how the engine runs under acceleration or even at a steady speed. As for ports on the intake, the only ones I'm aware of are the port for the fuel pressure regulator, the port in back for the power brake booster and then the evap canister purge valve, which I'm still running.
Old 06-19-2020, 09:31 AM   #7
shortboxin
shortboxin's Avatar
I will make this a priority Sunday morning when I'm off work. I get to work at 5:30AM and head home around 6:30PM. Then the 30-45 minute drive so it doesn't leave much time on work days.
Old 06-19-2020, 11:10 AM   #8
skyphix
Will do.
PCM Part #12200411
Drive by cable TB
Case grounded O2s
So, the PCM is from the same Z code vehicle right? Z code means flex fuel injectors which I assume you probably already know, and are different than the normal 24lb injectors in the non flex vehicles. If the injector parameters are off, it would cause this issue.
I agree though on checking fuel pressure. I’m running the same tank/pickup/EP381 pump, with a corvette fuel regulator/filter and -6an lines.
I do mean cold engine temp - you can hear the difference in my two videos between cold idle and hot idle. Cold idle is the revving video, hot idle is the driving video. My exhaust IS leaky (I need to reweld a couple of spots) but all leaks are after the o2s and it runs great.) Open and closed circuit fueling within the PCM is what I’m really referencing at a technical level.
EVAP purge at the front of the intake is what I was most concerned about. I blocked mine off. And the big brake booster 3/8 barbed fitting was the one that got me - totally forgot to plug that and it did what you describe.
Me saying it sounds leaky or like it’s running rough, could just be your video. It’s hard to tell without standing right in front of it. The exhaust manifolds only call for 13-15 lbs so should be ok there.
My suggestion would be fuel pressure (could even be too high if you’re not running a return system and don’t have any regulator online,) clean the throttle body thoroughly. If neither of those address it, a conversation with the tuner to verify your injector settings are correct.
Eric
1980 C10 SWB
Old 06-19-2020, 11:46 AM   #9
Mattchu60
I didnt read all the replies, but I recently did a 5.3 swap into my C10. The first 6-7 times I drove it, it would stall the engine whenever I shifted into D, or R.
Now it seems to have "learned" how to idle higher over time and the stalling issue has gone away. I did not change anything. It could be that it just needs some time to figure things out?
Mattchu60 is offline   Reply With Quote
Old 06-19-2020, 12:33 PM   #10
skyphix
You bring up a good point - what transmission?
Eric
1980 C10 SWB
Old 06-19-2020, 12:47 PM   #11
shortboxin
shortboxin's Avatar
First off, I want to say thank you so much for all of the feedback skyphix! I really appreciate it a lot.
It is the Z code PCM and the injectors are from the same vehicle, yes. I am unsure of what parameters this guy used since I mailed it to him and there was zero communication from him. Not even a note as to whether or not he got the specs from me.
I'm running my HVAC controls in the cab off of a tee in this line, but the issue has been there since day one before I tapped into this hose on Monday.
Running the factory vacuum controlled regulator on this thing. It's unlikely that I'll be able to get any communication with the tuner as he just doesn't respond to anything. Sadly, I'll probably have to get another PCM and get it programmed by someone else to see if that's it.
Old 06-19-2020, 12:49 PM   #12
shortboxin
shortboxin's Avatar
I was hoping for this originally, but I've driven it 1500 miles or so. The battery's been disconnected many times in between, but I've done 4-5 drive cycles up to as much as 130 miles on 2 of them and no change. Wish I was so lucky.
Old 06-19-2020, 04:17 PM   #13
shortboxin
shortboxin's Avatar
UPDATE: I contacted the tuner and he got back to me very quickly this time. I asked some additional questions which I added the second response as well.
1st response:
"Yes I just opened your file from June 2019 and everything matches below, injectors, rail, throttle, o2’s. Pretty much all stock air/fuel programming with changes needed for swap, security, emissions, so on, fans on… I use pre-configured files for most of my programming, files I’ve used on many swaps prior and know are good working combinations. The file for your PCM was one of these pre-configured that I may have only had to adjust one or two things to have it ready to your specs. This cuts out possibilities of mistakes on the many settings I do for a swap programming."
2nd response:
"It won’t throw codes for evap emissions, rear o2s, cats. So all sensors remaining, will run diagnostic tests as normal, coil controls, inj, temp, maf, air intake temp , so on, all will run as normal. P0300 misfire diagnostics for some reason do not work in swaps. I think the PCM want’s to see a fuel level to let them run (pcm ignores misfires if fuel level below 10%)."
Last edited by shortboxin; 06-20-2020 at 07:34 AM. Reason: Added tuner's second response
Old 06-19-2020, 05:14 PM   #14
shortboxin
shortboxin's Avatar
Missed this question... I am running a 4L60E. The Tahoe was running a 4L60E originally as well.
Old 06-19-2020, 06:42 PM   #15
layinrocker65
After do drive it for a while and the engine warms up, does the problem go away? What engine harness are you running?
‘53 GMC COE stock
Old 06-19-2020, 09:07 PM   #16
shortboxin
shortboxin's Avatar
It gets a little better, but it will still stall on occasion. I'm using the 2002 Tahoe harness that I modified per LT1swap.com.
Old 06-19-2020, 09:56 PM   #17
layinrocker65
The reason I ask is that I worked on a swap that the person had hooked up the constant power wires for the pcm to the ignition switch. The pcm did not like it and stumbled every start like it had to learn to idle all over again. Fixed the wires so they had constant power and issue went away.
‘53 GMC COE stock
Old 06-19-2020, 10:23 PM   #18
shortboxin
shortboxin's Avatar
I really wish it was that simple. I just double checked my schematic and wire list. Blue connector C1 pins 20 and 57 to +12V constant. It wouldn't hurt to double check my work on the truck when I have time on Sunday, so I'll make that a priority. Thanks for throwing me ideas.
Old 06-21-2020, 05:06 PM   #19
shortboxin
shortboxin's Avatar
Below is a list of the things I was going to address today. Didn't get #5 done yet... Fuel pressure could possibly be an issue, but I don't know if my gauge is 100% accurate. I tried to rent one to compare pressures, but Autozone was out of stock at all 4 locations near me.
1. Better video so exhaust can be heard and engine can be seen. DONE https://www.youtube.com/watch?v=Z9LVq95IQTA
2. Double check PCM C1 blue pins 20 and 57 to constant +12V. DONE
3. Check fuel pressure. KOEO = 54PSI, KOER = 44PSI at idle and 54PSI when throttled moderately. Also disconnected vacuum line while running and it came up to 53PSI from from 44PSI.
4. Verify that all of the spark plug wires are firmly snapped into the coil packs? Two clicks total for factory wires. Aftermarket wires, but verified coil pack side and plug side are all fully seated.
5. Clean out any gunk in and around the throttle blade, including pushing it open with your finger and cleaning any residue around the blade and hinge areas?
Old 06-21-2020, 10:57 PM   #20
layinrocker65
Definitely has a pressure problem that needs to be fixed. I’d fix that first to rule that out from anything else.
‘53 GMC COE stock
Old 06-22-2020, 12:06 AM   #21
skyphix
Yup. You’ve got a fuel pressure issue. Needs to be up around 58psi consistently.
Eric
1980 C10 SWB
Old 06-22-2020, 12:14 AM   #22
shortboxin
shortboxin's Avatar
I need to verify that my pressure gauge is accurate as well. I'll follow up with that in the next few days and post results.
Old 06-23-2020, 09:02 AM   #23
Rich84
Rich84's Avatar
When checking for a vacuum leak be sure to check the throttlebody itself. Mine was leaking at and around where the linkage passes through. It was only realized by doing a smoke test. It had very similar symptoms to what you describe.
Rich84 is offline   Reply With Quote
Old 06-27-2020, 05:59 PM   #24
shortboxin
shortboxin's Avatar
Okay, replaced my fuel pressure regulator last night and the pressure was identical. Figured I'd locate a pressure tester from a friend to make sure mine was accurate. In the meantime, I did a search for "fuel pressure testing ls engine" and immediately came across Bad Luck Garage's "LS ENGINE FUEL PRESSURE FACTS AND MISCONCEPTIONS". Very informative piece.
He breaks down the three different fuel systems of that era and the different expected pressures for each 1. returnless, 2. return style, and 3. return style - flex fuel. The returnless system should operate in the 58PSI range. The return style - flex fuel (my engine) should operate in the 42-50PSI range with vacuum connected.
He also explained that by removing the vacuum line, the pressure will come up to maximum (which I did early in the week and got 54PSI). On this system with vacuum disconnected, he states that the proper pressure is between 48-54PSI at idle. This would mean my fuel pressure is NORMAL. If you're interested, this is covered at 12:56 in the video.
https://www.youtube.com/watch?v=wA6mmc8fvQo
This guy performs his own tunes and sounds like he has a very strong grasp on the different systems. At this point, I'm going with the fact that I'm good on fuel pressure. I think my next best bet is to check for vacuum leaks around the throttle shaft on the throttle body per Rich84.
Old 06-28-2020, 12:17 PM   #25
layinrocker65
I’d still wonder if the tune is not correct for the fuel pressure. You don’t have a standard regulator you can throw on?
‘53 GMC COE stock
