Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 08-14-2020, 01:18 PM   #1
69Tom
DIY/SB - anyone ever use
I'm somewhat intrigued by this, for the main reason of keeping down on the massive amount of dust that comes with using my portable blaster. I'm always skeptical of things that are too good to be true. As I'm in AZ, I'm not super concerned with water/bare metal, as it will most likely dry offer before any serious flash rusting occurs.
Anyone ever use/try it?
https://diysandblast.com/products/x?...o570rT_YA5_2Pc
69Tom is offline   Reply With Quote
Old 08-14-2020, 09:36 PM   #2
scott123
Re: DIY/SB - anyone ever use
I have not but I hope someone has.
I watched the videos and read the reviews.
I'm always skeptical of those pitches.
I read in the reviews to buy the ten pack of the ceramic nozzles as they wear fast.
Hopefully someone will post.
S
scott123 is offline   Reply With Quote
Old 08-15-2020, 09:24 AM   #3
truckster
truckster's Avatar
Here's a guy building a boat in his yard who's using one:
https://www.youtube.com/watch?v=mYtbPG1RKgY
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 08-16-2020, 11:29 AM   #4
Ziegelsteinfaust
I need one of those, and the boat guy looked like he was getting good results.
Makes me wonder if my electric pressure washer is enough or do I need the gas powered version???
Ziegelsteinfaust is offline   Reply With Quote
Old 08-20-2020, 07:30 PM   #5
aggie91
I'm just glad to be here!
aggie91's Avatar
I've been thinking about getting one of these. For less then $40 I think it is worth a try!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-21-2020, 09:08 AM   #6
67C10Step
67C10Step's Avatar
I have one and have used both sand and coal slag with it. Coal slag worked best but I had significant issues with water getting back into the suction tube and when that happens all bets are off.
I've been wanting to monkey with putting some sort of check valve in the sand suction line but have not gotten back to it. Perhaps I bought too cheap a unit but it was around $40.
1967 C10
1997 Ford Ranger
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 08-22-2020, 08:15 AM   #7
scott123
I'm going to give one a try.
I will post back in the next couple of weeks to see how it works.
I am normally not a gadget 'as seen on TV' kind of person but this one has me a little intrigued.
And I am sure at some point I have pissed away $40 on something worse.
Scott
Old 08-22-2020, 08:33 PM   #8
scott123
I just ordered one. I will post the review later.
If anyone is going to order contact them and ask a question. They will send either a 15% or 20% off coupon code to use on your order.
Scott
Old 08-31-2020, 10:43 AM   #9
Woodnears
Anyone know what pressure is needed to make this contraption useful?
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417
Woodnears is offline   Reply With Quote
Old 07-07-2021, 07:50 PM   #10
scott123
I had some regular play sand in a bucket and gave it a whirl a few months ago. The sand had some moisture and it would not pick up/pulled thru the tube.
Fast forward til now. I was cleaning up around the shop and the bucket of sand was in the corner. It had dried completely.
I gave the blaster a whirl.
It worked way better than I expected. I cleaned a sort of large cast iron bell.
The drawback is that in reality it is a two man job. One person to run the wand and another person to keep the sand pickup in the sand. It needs to be moved and re-positioned often.
Overall, not a bad way to drop $20.
Scott
