Old 08-19-2020, 01:46 PM   #1
65chevysub
65chevysub's Avatar
Receiver Hitch
I was given a receiver hitch that came off of a 67-72 Chevy pickup, and want to know if I can use it on my 84 GMC Sierra? I haven't had a chance to do any frame rail measurements.
65chevysub is offline   Reply With Quote
Old 08-19-2020, 02:38 PM   #2
TrybalRage
Re: Receiver Hitch
I don't think it will work.. I believe the frames are different widths, and you'll likely not have the right mounting hole locations.
1985 C10 Silverado LWB LS Swapped! Other Stuff
2010 Suburban 2500 LT 4WD
YouTube
TrybalRage is offline   Reply With Quote
Old 08-19-2020, 05:15 PM   #3
SCOTI
SCOTI's Avatar
Re: Receiver Hitch
Same widths. Different probable bolt hole locations. I used the 'hidden hitch' I purchased from ECE for my 68 on my 74 swb when it took over tug-boat duties. I had to tweak the bracket slightly so it cleared the rear shackle bracket but 4 of the 6bolts aligned beyond that.
Bought a 2nd ECE 'hidden' unit from ECE & it's under my dually now.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
