Old 08-22-2020, 09:07 PM   #1
Ricks1971
Ricks1971's Avatar
camper mirrors help
Does anyone know where I can find or buy a set of camper mirror like these? Thank Rick
Ricks1971 is offline   Reply With Quote
Old 08-23-2020, 12:13 AM   #2
Eyegore
What Hump?
Eyegore's Avatar
Re: camper mirrors help
Check out Short Hauls thread in Square Body and Builds "Bourbon" 1975 Suburban Scottsdale" He said:
"I tried out a new set from Petersen Lighting, their "810" model, which lists as a universal fitm but it turns out the lower arms are a few inches shorter than the originals."
So other than that he said to look around at wrecking yards & CL
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 08-23-2020, 09:25 AM   #3
Ricks1971
Ricks1971's Avatar
Thanks this will help
Old 08-23-2020, 10:35 AM   #4
hatzie
Moderator
hatzie's Avatar
The early CK tripod mirrors tend to tear the door skins at the mounting points.
You can Frankenstein a set of large glass power dumbo mirrors that work quite well for towing and don't look out of place on the CK trucks.
Merge the Dumbo door mount from the CK & RV trucks with the 90's G series van stem and power mirror.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 08-23-2020, 11:15 AM   #5
Eyegore
What Hump?
Eyegore's Avatar
There to be some on Tucsons cl
https://tucson.craigslist.org/pts/d/...139454307.html
Lil red 86 c-10
99 Sub
Old 08-26-2020, 01:43 AM   #6
PAWS 72
PAWS 72's Avatar
Go to a big truck parts store and see if they have what you want. The one close to me has those mirrors and door mounts
PAWS 72 is offline   Reply With Quote
Old 08-26-2020, 10:02 AM   #7
ShortHaul
ShortHaul's Avatar
Rick, I’ve been on the hunt for a set for some time, my 75 Burb came with those mirrors originally, and the mounting holes are still visible in the doors. As Eyegore mentioned above I’ve tried and failed at sourcing a new set from Peterson lighting... they look identical but don’t match up to the holes. My question for you is, are the mounting holes in the door there? Or are you just trying to add a set of camper mirrors where there were none before?
"Sweet Pea" 1975 Cheyenne 20
http://67-72chevytrucks.com/vboard/s...00#post8477900
"Bourbon" 1975 Suburban ScottsdaleSOLD
https://67-72chevytrucks.com/vboard/...49#post8769049
”Otis” 1970 C10 SWB -SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=762766
”Chebby” 1962 Impala LS/TKO-500
http://www.pro-touring.com/threads/1...2-Impala-Build
ShortHaul is offline   Reply With Quote
Old 08-26-2020, 12:00 PM   #8
1976gmc20
A lot of those original four point below eyeline mirrors got ripped off and the doors destroyed by women drivers
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 08-26-2020, 04:04 PM   #9
Eyegore
What Hump?
Eyegore's Avatar
Not entirely true, I replaced mine in favor of the dumbo mirrors, much cleaner look since I was not packing a camper on the back
Lil red 86 c-10
99 Sub
Old 08-26-2020, 05:11 PM   #10
1976gmc20
"A lot"
Old 08-28-2020, 12:39 AM   #11
mr48chev
mr48chev's Avatar
There used to be a set of those in my junk pile before I loaded up that stuff for scrap.
They are about the quickest way to mess up a good door as anything you will find. My uncle had something like those on my 71 when he had it and hit stuff and destroyed both doors.
My ongoing truck projects:
Old 08-28-2020, 04:48 PM   #12
1976gmc20
We had them on our 71 and I never bumped anything but my wife hit a parked pickup with the RH mirror (just tore out the screws), and I heard later that the young gal that we sold it to tore up one or both doors pretty bad
Old 08-29-2020, 12:45 PM   #13
Pontiac1976
Pontiac1976's Avatar
Do you have the mirrors in ok shape or do you need brackets or need complete mirror and Brackets. The after market Truck supplier of the day and all the short reg 3 bolt point mount mirror fit the Brackets that way it may give you more options. Did have set of Brackets over the hot water tank yr's till the tank blow because I wanted larger mirror again I had found no nice used reg short 3 bolt point mount mirrors then found 4 or 5 bolt point mount set mirror just used the mirror's .
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
