Old 08-26-2020, 04:14 PM   #1
CanadianGMC
1962 GMC 910 4x4
Hi everyone,
I’m looking for some info on a truck I will be buying to breath some life into my project. If anyone that knows a thing or two about Canadian GMCs.. The truck I’m buying is a 62 GMC 910 and it’s on a 4x4 frame. It’s been sitting for 30+ years and I only have a VIN to go off of. I will be picking up the truck tomorrow but it’s 10 hours away so can’t get anymore info until I pick it up.
Here's what I know going off the VIN:
2: 1962
C:Should be 2wd but may be 4x4?
9: Canadian GMC
15: 127'WB
34: Long box fleetside
6:Inline 6 engine probably a 235ci
14040: Assembly #
A: Should be 5200GVW
From what I’ve gathered online is that the 60-66 4x4 frames were all the same just a bit of different locations for some suspension components. I also know that like most other Canadian versions this truck is basically a Chevy with GMC badging on it. Is there a location on the frame that I can check the ID to match it to the body to confirm if it was built as a 4x4? Going off this site: http://www.oeltd.net/doc/6066gmc/VINs/gmc-canada.htm I cannot see any 4x4 models being produced for the Canadian market from 60-62. Maybe I’ve stumbled on a rarity? Anyway, any additional info I can gather would be greatly appreciated.
CanadianGMC is offline   Reply With Quote
Old 08-28-2020, 03:54 PM   #2
MusicMan70
MusicMan70's Avatar
Re: 1962 GMC 910 4x4
Maybe a cab swap before you got it?
I have a 61 and there is not a VIN number stamped anywhere on the frame. I read that the GMC's are like that.
The alternate place I'm told to check is above or the top of the frame just below the driver side.
I looked using a mirror but found nothing. Your results may be different. Check there and let us know.
Bump for you as well.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 08-28-2020, 10:11 PM   #3
Captainfab
60-66 Nut
All I'm going to say is look very closely at how the VIN tag is attached. That should answer your question.
Old 08-29-2020, 12:06 AM   #4
'63GENIII
'63GENIII's Avatar
No Rosette rivets and elongated tag holes Cap'n?
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 08-29-2020, 04:24 PM   #5
raylube
raylube's Avatar
Cool truck,hope the mods don't close this thread down due to vin "tempering" is illegal. Should be a fun build.
raylube is offline   Reply With Quote
Old 08-29-2020, 09:24 PM   #6
short&wide65
With the second digit being a C not a K it is highly unlikely that truck was originally built as a 4x4. You're probably right that there weren't any factory built 4x4's in Canada until 1963.
There is a service in Canada that will decode the VIN for you and tell you how the truck was originally built.
https://www.vintagevehicleservices.com
On Canadian trucks there is a number stamped in the frame which corresponds with the VIN. My truck has it but I just can't remember how many numbers it has. It's on the driver's side of the frame.
1965 GMC 910 Short Fleetside.
2014 GMC 3500 HD Long Fleetside
short&wide65 is offline   Reply With Quote
Old 08-29-2020, 10:41 PM   #7
Captainfab
60-66 Nut
Yep, it's quite obvious that the VIN tag has been tampered with
Old 08-29-2020, 11:57 PM   #8
ApacheNick
I do agree that the VIN looks to have been tampered with because of the elongated holes, but I would like to see some good, straight on pictures of those rivets. I don't know exactly what year the Canadian built trucks started using the rosette rivets but I do know the early ones used round rivets with a large center hole. I've seen them on every 60-63 I've looked at including my own two.
EDIT:Just looked at my truck, and the one in the pic really looks like standard pop rivets.
Another thing, and someone correct me if I'm wrong, but I thought they started doing the partial VIN stamp on the frame in 63 for the Canadian trucks.
Nick
1961 Apache short stepside 4X4 SBW 348/4 speed
1960 Apache C-20 long fleet custom cab BBW 283/4 Speed
1967 rust bucket Olds Cutlass with a 455
1972 GMC K-15 350/4 speed long fleet
ApacheNick is offline   Reply With Quote
Old 08-30-2020, 12:05 AM   #9
ApacheNick
On the topic of the frame, the cab mount brackets changed in 63.Don't know if anything else did or not.
Nick
Old 08-30-2020, 10:31 AM   #10
short&wide65
I think you might be right. I may have misspoke when I said this truck would have that number stamped in the frame. I know more about the 63-66 trucks than I do the 60-62's.
Old 08-31-2020, 08:15 PM   #11
Corts60
Just here to tinker
Corts60's Avatar
I think you are correct. I understand they narrowed the frame in '63. So 60-62 trucks have same frame and 63-66 are the same.
Old 08-31-2020, 11:29 PM   #12
CanadianGMC
Looking at the rivets in the picture I have to agree, this may have been vin swapped... I do not plan to use this cab as I will be using another cab that I've had for years. The rivets on the other cab look stock. Either way, I picked the truck up last Friday. Upon seeing it I can tell it's not the stock frame for this truck. I'm now just trying to determine if its a 63-66 or 67-70 4x4 frame. This week I'll clean it up(30 years worth of mouse droppings) then get to measuring the frame and trying to start it up.
Here's some pictures from picking it up, in my driveway with my 56' Pontiac Laurentian beside it and the VIN from the cab that I will be using for this build
Old 08-31-2020, 11:34 PM   #13
cwcarpenter98
cwcarpenter98's Avatar
Judging based on the frame horns, it looks like it's probably a 63-66 frame
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 08-31-2020, 11:36 PM   #14
CanadianGMC
I'm hoping that's the case. Either way I'll switch over to my build thread here. My other truck's pictures are there. I can't wait to get this project underway!
My project thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=809162
