Old 09-05-2020, 10:02 PM   #1
brwn70gmc
72 burby fuel tank sending unit with return line?
My 1972 Highlander Suburban has a fuel tank sending unit with a supply and return line, yet my LMC stock replacement arrived with only one supply line.
Do they make a single line sending unit or do I replace the fuel pump and disregard any return lines?
brwn70gmc is offline   Reply With Quote
Old 09-06-2020, 12:32 AM   #2
HO455
HO455's Avatar
Re: 72 burby fuel tank sending unit with return line?
If the correct unit isn't available I would modify your new one. I soldered a return line into the sender on my Burban. See photos in the link.
https://67-72chevytrucks.com/vboard/...698377&page=16
RIP Bob Parks.
Old 09-06-2020, 08:57 PM   #3
brwn70gmc
I'm trying to install my LMC replacement tank and the filler neck is too short? It will kink the rubber filler line as it comes out of the tank. Do you have to transfer the old filler neck to the new tank or do I have the wrong tank...
Old 09-06-2020, 09:07 PM   #4
HO455
HO455's Avatar
This thread is probably the answer to your question. If not do a search as this is a known issue and several fixes are out there.
http://67-72chevytrucks.com/vboard/s...d.php?t=779043
RIP Bob Parks.
Old 09-10-2020, 01:04 AM   #5
BAD1916
When I replaced the fuel tank on my Suburban I cut off the filler neck and welded it to the new tank.
BAD1916 is offline   Reply With Quote
