Moderator
![]() ![]() Join Date: Aug 2011
Stepside 10" Rear Wheels
So I saw a post online where a guy says he has 10" wide rear wheels (pic shown) is this possible?
255/50r16 (26”)rear tires with 10" wheels in back. https://tiresize.com/tiresizes/255-50R16.htm
Moderator
Re: Stepside 10" Rear Wheels
Cause if that's the case I could up-size to a 17" in the rear and go big-little front and rear.
https://tiresize.com/tiresizes/255-45R17.htm
I wouldn’t believe unless I measured them myself.
Don’t look like 10’s to me. Must have a deep bs. Read this. Easy to measure yourself. https://www.hotrod.com/articles/ccrp...heels-fitment/ And bigs/littles means tiny short 24-26 front, 30-32 back. Might look a bit goofy with a shorter sidewall on the back. |
Moderator
I know I have 6 inches clearance on the inside of the wheel mounting space in the frame. To the fender lip I have 6 inches. However I forget how much less as it gets higher on the inside of the rear fender...
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 10-02-2020 at 03:31 PM. |
Moderator
I just looked at that picture, there is light showing on the ground behind the wheels.
But Found Her 25yrs Later!
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#7 | |
Moderator
I guess I get all excited to buy stuff when I can. Calm deep breaths, I'll be home in a few months.
Definitely let me know what you come up with. I was wanting to run a 12in wide tire on a 10in wheel. I previously picked up some original fleetside inner fenders , for the possibility of having to tub it a little.
My wheels will be factory wheels banded. I still need to figure out the wheel offset. Posted via Mobile Device |
Moderator
What does "banded" mean?
Made wider, with a "band of steel."
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
Just as Skinny G said , I am just rolling a piece of 3/16 and welding a band in wheel to make it 10in wide and also change the offset to what is needed.
Which I don’t know what offset I will need. 12 in wide tire in a stepside fender well with a swapped in factory 71 GM12T. Posted via Mobile Device |
Did you know they make a handy tool to measure accurately.
Like this. https://www.summitracing.com/parts/php-01201 |
#13 |
Moderator
I used to explain wheel backspace to people in 1974 and was looked upon as a heretic.
#14 | |
Just because it fits one combo doesn't mean it fits all combos; especially w/40+ year old vehicles. 'Ya need to know/understand the dimensions of your combo to make the best decisions.
| Bookmarks |
