![]() Join Date: May 2015
Suburban Gas Tank in a K30 CC
I ordered a 40 gallon suburban tank to install behind the rear axle in my K30 crew cab.
I looked at some threads with a filler in the bed and modifying the fuel door. Curious what people are doing for fillers these days. Headed to go pick up my bed from the painter today. Thanks, 13 |
Re: Suburban Gas Tank in a K30 CC
Filler in the bed = easier to fill. I know guys have made fill tubes to allow using the OE door set-ups but to me that just asks for issues (constant shutting off the flow while filling).
A discrete fill setup off to the side (adjacent to the stake pocket) allows an easier path for the gas flow while not impeding use of the bed floor.
I am not overly excited with a filler door on the bed floor.
Funny you recommend that - I found this last night and like how this lays out. Thanks, 13 |
#4 | |
*EDIT* I modded a swb steel floor for a 'through the floor' fill & used the neck & cap from a 67-72 in-cab gas tank since the size was more than adequate & they make a rubber grommet for the exterior sheet metal to seal the inside of the cab off. Of course there are much 'slicker' versions/options available as well.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-09-2020 at 10:44 AM. |
#5 | |
Much smarter. 13 |
Tweaked 67-72 set-up I mentioned....
You also might have issues with the shock mounts on a k30. The suburbans, blazers, and the lighter duty trucks all had the shocks on the outside of the frame. The 1-tons moved the shocks inboard. I've heard of folks adding the suburban tank to the c30/k30 trucks, but it often involves some intentional denting of the tank to get enough clearance.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
#8 | |
Ive thought about doing a pop up cap inside the stake pocket. Not sure how feasible that is.
#12 | |
I feel better about a bed filler with surrounding linex. Posted via Mobile Device |
| Bookmarks |
