11-11-2020, 06:36 AM | #1 |
Ls manifolds/ headers
I have a 72 c10 frame with 6.0 /4l80e combo sitting in it. I used ingenuity fab and speed 67-72 mount and crossmember kit. Does anyone know what manifolds or headers will clear and not interefere with dipstick tube or spark plug wires?
Thanks Posted via Mobile Device |
11-11-2020, 07:28 AM | #2 |
Re: Ls manifolds/ headers
Look in the build section "71 LS Stepside ".....I think he used speed engineering headers....shoot him a msg ask how the fit?
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
11-11-2020, 08:23 AM | #3 |
Trailblazer SS Should fit they also made a TB without the SS that had a 5.3 that carries same manifolds. They are still available new. Jim
11-11-2020, 08:43 AM | #4 |
2010 Camaro manifolds with heat shields removed and smoothed up
will be sending them to be jet coated soon plenty of clearance and years of leak-free, trouble-free operation on 2001 5.7 LS1 Transmission and oil level dipstick fit perfectly
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
11-11-2020, 10:20 AM | #5 |
Almost Satisfied
Speed Engineering long tubes is what I am running with the same set up. I'm sitting on POL engine stands, but you won't have issues. You will have to trim the ears on your transmission bell housing. You can look in my build thread to see them.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
11-11-2020, 10:45 AM | #6 |
The Older Generation
I used the Hooker Cast Iron headers/manifolds in the pictures below on my '67 Panel Truck with an LS1. Cleared everything with no problem. I bought them off of E-bay. It looks like these might be about the same and on sale.. https://www.holley.com/products/exha...st%20Manifolds You have to watch that price. That is per manifold. I don't think I have ever seen anyone sell them one at a time....... Any way it automatically added 2 to my cart. Dunno. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-11-2020 at 11:03 AM. |
11-11-2020, 11:32 AM | #7 |
Old member
I used the S/S headers for a late model Camaro.
Here is a link with them and some others. "Stainless Work Headers" http://67-72chevytrucks.com/vboard/s...d.php?t=695713
11-11-2020, 11:42 AM | #8 |
Almost Satisfied
Not the greatest pictures, but all I have on my work PC. If you need to see anything else let me know. I'll look for a shot of the trans where the header goes by.
11-11-2020, 08:40 PM | #9 | |
https://www.speed-engineering.com/featured-products/ls-conversion-swap-headers-camaro-chevelle-nova-c10-truck.html Posted via Mobile Device |
11-11-2020, 11:05 PM | #10 |
I used 2010 Camaro manifolds and they fit great. Used with an F body oil pan and dipstick
1965 c/10 swb 1969 c/10 lwb |
11-12-2020, 10:28 AM | #11 |
Almost Satisfied
Larry, here is what I have.
https://www.speed-engineering.com/ls...2-ls3-ls6.html The ear on the passenger side of the 4L80e has to be trimmed down to clear the long tube header. If you go with the shorty header in your link then you don't need to modify the transmission.
11-12-2020, 06:41 PM | #12 | |
11-12-2020, 07:54 PM | #13 |
I used Speed Engineering's shorty headers with my 6.0/4L80 combination and had to trim the ears on the trans.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
11-13-2020, 08:30 AM | #14 | |
11-13-2020, 11:31 AM | #15 |
You can still use the dust cover.
Trailblazer manifolds..Had to cut. |
11-16-2020, 10:50 AM | #16 |
Just installed these on my Brother’s 66 with Fbody oil pan and EBay mounts. From Summit and fit like a glove..
11-16-2020, 10:51 AM | #17 |
11-16-2020, 03:59 PM | #18 | |
11-18-2020, 01:42 PM | #19 |
11-19-2020, 09:21 AM | #20 |
Has anyone 1947-1953 chevy truck used the Summit cast iron manifold with 5.3 and had any luck with clearance issues ?
