Old 12-01-2020, 10:01 PM   #1
MrBlue
MrBlue's Avatar
Black Oxide Bolts
In the middle of some TLC updates on my C-10. As I have the front end apart and don't want to buy new bolts, I was looking at wire brushing them and then coating them with a black oxide coating.
Does anyone have experience doing this?
MrBlue
72' C-10 350 TKO-600 Current Project
54' Ford F-100 Life Long Project
MrBlue is offline   Reply With Quote
Old 12-02-2020, 07:42 AM   #2
Thealien
Thealien's Avatar
Re: Black Oxide Bolts
http://67-72chevytrucks.com/vboard/s...d.php?t=264150
When you click the link in that thread it will bring you to a page not found on the caswell website.In the header at the top you will see black oxide where the solutions are there.
Old 12-02-2020, 09:13 AM   #3
52napco
Buy new bolts. It's a lot easier and cheaper than glass beading and phosphate
coating your originals by far.
52napco is offline   Reply With Quote
Old 12-02-2020, 10:02 AM   #4
Grumpy old man
Grumpy old man's Avatar
Buy new , Auveco 15792 . All the best OEM style clips fasteners and bolts come from Auveco .
https://www.auveco.com/hex-hd-sems-b...18-x-7-8-15792
50 shipped for $20.58 - https://www.amazon.com/Qty-5-16-18-S.../dp/B071QYSYNK
50 - $13.89 - https://autofastenersandclips.com/pr...nt=19614148999
50 - $ 13.97 - https://www.fastener.zone/products/a...75-gm-15686047
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 12-02-2020, 10:38 AM   #5
SRU1436
Thank you for the link to that website. I’ll be using it for my truck and chevelle.
SRU1436 is online now   Reply With Quote
Old 12-02-2020, 10:44 AM   #6
Grumpy old man
All Fastenal stores carry Auveco hardware .
Old 12-02-2020, 10:56 AM   #7
DeadheadNM
Carpe manana
DeadheadNM's Avatar
My experience has been the complete opposite and for black phos all I've ever done is knock back gross deposits of debris from the parts with good results. I've got a batch out for plating right now.
It's typical that shops have a minimum rate and that typically gets you pounds of plated fasteners, latches, hinges, etc.
Old 12-02-2020, 11:08 AM   #8
70STOVEBOLT
70STOVEBOLT's Avatar
I got a bottle of Jax for my birthday and it works well. You don’t need the kit, just the blackening agent you can finish them with WD40 or penetrating oil.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 12-02-2020, 11:15 AM   #9
tim_mc
tim_mc's Avatar
I've redone OEM bolts using the same method as 70STOVEBOLT with good results. If you have a bead blaster or wire wheel then this is a good option. I bought a pint of Caswell Black Oxide Concentrate and use WD40 as the sealer. Here's a good video from Cuda Cody on the process:
https://www.youtube.com/watch?v=7vTn6l5h67A
I've also bought replacement OE-style bolts in bulk at good prices.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 12-02-2020, 02:58 PM   #10
Thealien
Thealien's Avatar
Thanks, I don't think I'll be doing any more black phosphate unless it is a few odd fasteners.
