Old 12-11-2020, 12:07 AM   #1
truckster
truckster's Avatar
Body Mount Shims
I replaced my body mounts with new ones from Wes at Classic Heartbeat. I went from 3" spacers to stock height. When I reinstalled the front fenders I had to shim the front tub mounts by 3/8 on one side and 1/4 on the other side to get the gap between the fender and door even.
My question is about the other body mount bushings. How do I figure out how much to shim them? Do I split the difference?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 12-11-2020, 12:27 AM   #2
Spf79
Spf79's Avatar
Re: Body Mount Shims
I will have the same question soon, following along. I have the same mounts.
Full top blazer or bust....
Spf79 is offline   Reply With Quote
Old 12-11-2020, 08:19 AM   #3
A1971Blazer
A1971Blazer's Avatar
It looks like you should shim under the remainder enough to "table" (or close the gap I suppose) between the body and the mounts...
Name:  Body Shims.jpg
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 12-11-2020, 12:03 PM   #4
truckster
truckster's Avatar
Thanks.
Old 12-16-2020, 11:22 AM   #5
hemi43
hemi43's Avatar
These trucks were built with a +- tolerance of 1/4", so the number of shims at each point is irrelevant, so having more on one side is probably OK. What determines how much shim you need is the door gaps.
hemi43 is offline   Reply With Quote
Old 12-16-2020, 07:41 PM   #6
truckster
truckster's Avatar
The door gaps are good now, and the body mounts are all torqued to spec, so I think I'm OK. Thanks again.
Old 01-04-2021, 11:32 PM   #7
k-nuts
k-nuts's Avatar
What torque specs did you use? also are the rear mounts (lower bushing) compressed a whole lot? See pics in recent post on body bushings
TIA
k-nuts is offline   Reply With Quote
Old 01-05-2021, 08:31 PM   #8
truckster
truckster's Avatar
TIA
I looked for the spec sheet I got from Wes in my file (which is really just a drawer in my toolbox) but I couldn't find it. I remember there was a range, and I believe I set my torque wrench at 45 ft-lbs for all but the radiator support bushings. You can see how much the bushings compressed in this pic.
Old 01-05-2021, 09:34 PM   #9
k-nuts
k-nuts's Avatar
Thanks!
Old 01-06-2021, 10:36 PM   #10
Toro
Toro's Avatar
Here's a picture of the same mount on mine and it looks pretty much the same. There is a separate thread I started asking about this, and I'm relieved to see someone else's results. I tightened mine just enough until the center sleeve/bushing started to make contact with the washers on the upper and lower cushion. My kit came from GMC Pauls.
Toro is offline   Reply With Quote
