Old 01-08-2021, 10:17 AM   #1
57FleetsideC4
Steering column choice for 57
Hi, Doing a 57 pickup with C4 suspension. What is everyone using for aftermarket steering columns? I have read the cheaper ones are dangerous as the internals are weak. It has a 31" chevy van column in it now but what somthing cleaner looking. Looking to get somthing soon as I am mocking up everything on the truck now. Thanks Steve
57FleetsideC4 is offline   Reply With Quote
Old 01-08-2021, 10:28 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Steering column choice for 57
ididit makes some nice stuff
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-08-2021, 11:47 AM   #3
DPete
DPete's Avatar
That's what I have, has tilt & emergency flashers, soild construction
56' 3100 shortbed
DPete is offline   Reply With Quote
Old 01-08-2021, 12:43 PM   #4
svr
svr's Avatar
I used a late '70's floor shift pu column, tilt, turn signals and flashers. I shaved the key switch and lock. i'ts a bit long but works good. Got it for $50 and spent a bit on new signal switch and bottom bushings making it new.
57 short box, 235, T5, C4
http://67-72chevytrucks.com/vboard/s...d.php?t=739132
svr is offline   Reply With Quote
Old 01-08-2021, 01:01 PM   #5
mr48chev
mr48chev's Avatar
Ididit or Flaming River if you want clean aftermarket.
I've known a couple of guys who bought the cheap aftermarket ones and ended up replacing them in a short period because they got loose and there was no way to tighten them back up as there is on a GM factory column. You can go into a factory GM column and tighten it up if it is a bit sloppy. My wife is terrible for using the steering wheel to pull her self forward to reach the key or do what ever and I was always having to go into them an tigten them up.
I wish someone in the aftermarket would sell a collar/body that was minus the key switch to replace the one on a 70's Chevy truck tilt column. That piece if it were high quality would let you buy a wrecking yard column and make a real clean column out of it.
My ongoing truck projects:
Old 01-08-2021, 01:18 PM   #6
regan56
Following this thread.
regan56 is offline   Reply With Quote
Old 01-08-2021, 03:30 PM   #7
_Ogre
_Ogre's Avatar
GM makes some nice stuff
shop air compressor timer
Old 01-08-2021, 05:23 PM   #8
57FleetsideC4
Thanks for the input guys. I have been looking at the ididit and flaming river columns and they look nice. It's hard to see the difference between a $300 column and a $1000 column. If its saftey it would be cheap insurance to get the ididit,flaming river. Steve
Old 01-08-2021, 08:37 PM   #9
regan56
What vehicle is that out of? I do like the looks of it
Old 01-09-2021, 05:32 PM   #10
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Nice!
Love the interior. I'm contemplating options now for a console and runner along the bottom of the dash for A/C vents.
87Lowrider is offline   Reply With Quote
Old 01-10-2021, 06:23 PM   #11
_Ogre
_Ogre's Avatar
it's definitely safety related. the cheap columns are know to break at the tilt column joint and send the vehicle in the ditch or across the center line. i'll let dsraven post the link, i'm not seeing it now
gm spent millions and years of engineering to perfect the steering column
my column came out of an 86 gmc safari minivan, same van as the astro
it's pre-airbag with tilt, turn, key on column and hi/lo dimmer
you do need to cover up the bottom if you worry about fugly
i used the van steering wheel, always meant to put on a classic wheel, but i like it
nicest thing? IT COST ME $35
Old 01-10-2021, 06:32 PM   #12
_Ogre
_Ogre's Avatar
Originally Posted by 87Lowrider View Post
Nice!
check out my build.
lots of pics and info on my dash fascia/console/sub enclosure
i learned fiberglass on this truk
Old 01-11-2021, 12:56 PM   #13
regan56
I have been looking for a nice GM column and this one fits most bills. I may have to rethink, i was looking for a column with the external PRND(O)L display for my 700R4, probably available in a older GM van though too.
Old 01-11-2021, 02:48 PM   #14
_Ogre
_Ogre's Avatar
the length of the astro column was just right
the astro is a 3 speed with the wire pull for PRNDLL, i used a stick on PRNDLLL from ididit
the shift lever is on the left side, makes for lots of room to work, but you gotta reverse the shift
i did this with an intermediate shaft, this shaft also changed the 3spd into a 4 spd
i added pics that show the fugly and the mount
Old 01-12-2021, 04:50 PM   #15
SCHRUMGMC
SCHRUMGMC's Avatar
I like the way the IDIDIT columns look and I am getting another column here soon
Mine will be painted and matched to make it look like it was made for that truck(originally)
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 01-12-2021, 05:48 PM   #16
_Ogre
_Ogre's Avatar
unless your made of money, the $35 jy column makes sense, schrumgmc
you can always change it out later as they wire up with the same plugs
a 28" paintable ididit tilt column is over $700
Old 01-12-2021, 08:38 PM   #17
SCHRUMGMC
SCHRUMGMC's Avatar
Yeah the column I’m getting is $864 out the door... pretty expensive
It’s all in what you like I guess.
1971 GMC Sierra
1959 GMC 100
Old 01-13-2021, 10:37 AM   #18
57FleetsideC4
Lots of great suggestions here. What is the typical length is everyone using? The column that came with the truck was a 89 chevy van and the lower shift lever is on the opposite side so getting the linkage on will be tough. The length is 31" and am thinking 28" or 30". Steve
Old 01-31-2021, 12:14 PM   #19
57FleetsideC4
I have a follow up column question. I got the original bench seat and the steering column in. It has a CPP brake booster/pedal relocation kit already installed. The problem is with the column in the straight position by the time I reach the brake pedal my knee is against the bottom of the steering wheel. the column is a 89 chevy van and is 31". I am getting a new column so would it work to get a 33" column to get the wheel out further? The pic shows what I am talking about. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
Old 01-31-2021, 02:51 PM   #20
_Ogre
_Ogre's Avatar
change out your column mount to have the column almost touching the dash
i'm 6'4" and raised the drivers seat 2" over the bench height to give me more leg room
i have the plastic column trim 1/4" away from the dash,
didn't realize i messed up until the speedo went in
i had to grind the point off my cluster trim ring
it works, it also looks like my wheel is higher than yours
i typically run the column tilt straight
Old 01-31-2021, 06:25 PM   #21
57FleetsideC4
Thank You. Trying to figure this stuff out before I disassemble for body work. Yours does look higher up than mine. Steve
Old 02-01-2021, 03:25 PM   #22
_Ogre
_Ogre's Avatar
hard to tell with that very iffy pic you posted
Old 02-01-2021, 05:23 PM   #23
57FleetsideC4
Ogre, Here are some more pics. My original pic was to show how my leg would go up against the steering wheel if I tried to use the brake. Thanks Steve
Old 02-02-2021, 02:05 PM   #24
_Ogre
_Ogre's Avatar
your column is a little higher on the floor and a little lower on the dash vs truk
just a little here and there obviously makes a lot of difference
not sure if your steering is locked in yet, now would be the time to fix the column layout
maybe moving the bottom down an inch would make all the difference
Old 02-02-2021, 02:08 PM   #25
_Ogre
_Ogre's Avatar
i think our columns are the same height just not the same angle
maybe these will help
