Old 02-09-2021, 07:45 PM   #1
joelbert62
Question Static drop suspension clearance
Got back to my 64 LB C-10 Rebuilt rearend 3;73 posi 4-inch drop w classic 4inch Hd springs shock relocation brackets w new shocks new trailing arm bushings, breaks n, and the adjustable Panhard bar. On the front, I cut 1.5 coils off. truck rallies and 235/70 r 15" around can not wait to see how it sits.
The question, when I adjusted the Panhard bar, I used my floor jack under rearend , all trucks rear weight on the jack/suspension. adjusted till centered using plumb bob off fender to measure to the axel. BUT when the weight is on it the rubber snubber is almost hitting the rear end. maybe 2.5-3" of travel till hits on the frame.
As I researched before I started a 4-inch drop in the rear required NO adjustable Panhard bar( that was wrong, the stock one would not fit back in) and NO C notch. Do I cut the snubbers off leaving a 1/4 inch of rubber to hit on? or?? Am I looking at or doing something wrong??
Thanks Joelbert
Thanks Joel
joelbert62 is offline   Reply With Quote
Old 02-09-2021, 07:51 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Static drop suspension clearance
I cut mine off. I left just enough bumper to let it hit. I used dropped coils in the back. No c notch. I added helper air bags in all 4 corners and my 71 LWB rides great. I run 20 lbs in them all the time. No bottoming out ever anymore. No Limit rear shock relocator kit and adjustable bar which by the way isn't adjustable unless you take one end loose. I love the way it rides.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-09-2021, 07:54 PM   #3
joelbert62
let me ee if I can get my Phots back on here?
back to my project
