Old 03-29-2002, 05:51 PM   #1
Kas68c10
Kas68c10's Avatar
Post Rear trailing arms ???
Had a strange clunking noise in the truck,and acceleration and braking.Checked the clutch,tranny,u joints,and calipers,no luck. Finally jacked truck off the ground fron the frame and saw a space between the trailing arms and the rear axle.Tightened up the u bolts and now no noise. Problem is, looks like the arms are starting to collapse.Anybody got some good used one for me ? Got a decent price from Ed at Mothertruckers,but I haven't dealt with him before.Any opinions board ? Wes or Paul, have you guys got any ? Probably will change coils springs as well, will need cups and hardware,looking for inner fenders also...Any opinions appreciated.
1968 SWB Stepside, pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,3 bolt seatbelts, original i6 and wood bed, seat from an 89 Chevy, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,WORK IN PROGRESS,Daily driver, 20 MPG, Freeland MI
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline   Reply With Quote
