Old 06-23-2021, 05:49 PM   #1
barmanvarn
barmanvarn's Avatar
Alternator pulley not lining up
Had to replace my old alternator today as it started making a horrible racket.
Local parts place had a new one in stock and it SEEMED to be identical to my old one. Only when I got the new one installed did I realize the pulley is about 1/4 inch out of alignment towards the rear.
That being said, I don't see any means of adjusting the alternator forward any. With the way it mounts, it's locked it place between two brackets so it can't move forward or backward.
I've never run into this before so not sure what I should do. Do I try another alternator and hope it lines up? Do I get new upper and lower mounts that would allow me to align the pulley (if they even exist)? Do I have a shop shim the pulley for me?
thanks in advance
Brian
'69 GMC C15
Inline 6, 230ci (possibly 250ci)
barmanvarn is offline   Reply With Quote
Old 06-23-2021, 06:09 PM   #2
body bolt
Re: Alternator pulley not lining up
Get another alternator and compare it to this one before you leave the store.
body bolt is offline   Reply With Quote
Old 06-23-2021, 06:19 PM   #3
barmanvarn
barmanvarn's Avatar
That's for sure my plan for now....just didn't want to spend weeks ordering different alternators only to find out I was doing something wrong. LOL
thanks
Brian
'69 GMC C15
Old 06-23-2021, 06:26 PM   #4
body bolt
This is assuming your original alternator was correct.
Old 06-23-2021, 07:12 PM   #5
gmc684x4
Go back to store pull pulley off and swap pulleys
gmc684x4 is offline   Reply With Quote
