07-14-2021, 08:04 PM | #1 |
Body repair advice
I have a 68 Chevy short bed step side that I am going to rebuild back to its former glory my plan is to restore it back to factory at least as far as I can I don't have the original motor or transmission but the biggest issue I have is the damage that happened to the cab. I have been searching for a donor for parts but there is nothing in my area and I know that replacement panels are not the best fitting from my past experiences but I can make them work. The main reason I want to save the cab is my wife and I are the 4 members of the family who own this truck and my sun will be the 5th. Enough of the back story here are some pictures of the damage that happened in the short time the family did not own it. Not only did he smash her he decided to strip all of the chrome off and for some stupid reason the vin tag
07-14-2021, 08:44 PM | #2 |
Re: Body repair advice
Look up pdr repair guys
The ones that are really good can do most repairs with no repaint the repair area One guy to look at is man of steel on YouTube I will recommend new corners and rockers if your going to paint it it would suck 2 to 5 years have your restoration ruined from not replacing these high rust areas |
07-14-2021, 09:02 PM | #3 |
When I start this project I'm going to do a frame up restoration I just don't want to be replacing the back panel if I don't have to this damage is a little more extensive than what I have worked on. Thanks for the tip I will check it out in the morning.
07-14-2021, 09:08 PM | #4 |
Stud gun / Steck studlever / heat / hammer and dollies and time will bring that back .
https://steckmfg.com/product/20014-studlever/ https://www.youtube.com/watch?v=MsC7vrgXj_0
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
07-14-2021, 09:45 PM | #5 |
It's very hard to "Eat the whole elephant" Why not get it running and driving. Make it fully functional and safe. Then start on the cosmetics. Repair the body panels one at a time while still driving the truck. It's easy to get discouraged with the truck blown apart.
07-14-2021, 09:45 PM | #6 |
Thanks Grumpy old man I will watch the video in the morning on my PC is there any way to replace the vin tag or to get a copy of the original build sheet the kid that wrecked her spray painted the inside of the glove box
07-14-2021, 09:50 PM | #7 |
She drives it has a 80's 305 with 1a 4 speed manual I would not hesitate to take it to work 100 miles round trip but she really likes her gas I do drive it around my little town and take her to the farm every so often
07-14-2021, 10:14 PM | #8 | |
All about them K’s
Vin tag replacement is a no-go conversation on this site for legal and a myriad of other reasons. Please don’t engage that conversation further. I agree with grumpy on the cab repairs. Most of my upper passenger cab corner got munched by the bed at some point in my trucks’ life. I was able to get it back pretty decent by doing what grumpy suggested.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
07-14-2021, 10:34 PM | #9 |
I think the vin tag he is referring to is actually the spid.
07-14-2021, 10:39 PM | #10 |
All about them K’s
That is a valid possibility, if that’s truly the case obviously that topic is just fine. If referencing the metal plaque, their in lies the no-go.
07-15-2021, 05:09 AM | #11 | |
07-15-2021, 02:18 PM | #12 | |
All about them K’s
That said, most of these old trucks can be made nice again with enough time and money. Good luck in your project!
07-15-2021, 03:28 PM | #13 | |
07-15-2021, 04:32 PM | #14 |
For the dented cab I would pull the bed off and get the truck on a frame rack and pull the dent out. The body shop can also measure the frame to make sure it's still square at the same time.
07-16-2021, 02:24 AM | #15 |
I would slowly strip the spray bomb off the glovebox. Going slow you may be able to recover the info
07-16-2021, 04:33 AM | #16 |
What would you use to clean the spray bomb off? Here is a picture of it but looking at it I'm not sure if it is there or if it is just the glue
07-16-2021, 08:22 AM | #17 |
That's not coming off without destroying the print , you do still have the vin tag in the door jam ? why would someone spray silver paint inside the glove box ?
07-16-2021, 08:56 AM | #18 |
That almost seems like a teenager move right there. Makes no sense but then again, we've all seen a lot that makes no sense.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
07-16-2021, 09:45 AM | #19 | |
07-16-2021, 10:00 AM | #20 |
Nothing to loose on the spid, you could try a razor blade strait up and down a small scraping action. Another possibility sanding with 600 wet dry paper.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
07-16-2021, 10:50 AM | #21 |
07-16-2021, 11:02 AM | #22 |
No I don't have the vin tag on the door that is why I asked about a replacement but the truck is titled and licensed. If I remember correctly he was 17 or 18 when he got the truck and when I bought it at auction they started the bidding at $5k everyone there knew who owned the truck and that I wanted it back I ended up paying $250 for it got to love living in a area where everyone knows who you are and your in-laws
07-16-2021, 12:02 PM | #23 | |
landarts
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
07-16-2021, 02:12 PM | #24 |
I know the autobody industry has came a long way since the last time I work on body panels about 25 years ago is there any specialty tools I should be looking to buy?
