Still plays with trucks
Moving grip surface of steering wheel fix?
Anybody have a fix for the common problem of the gripping surface of the steering wheel breaking loose from the inner steel ring and moving around under your hand when you use it?
I have a nice steering wheel I'd like to save if I could and just the top section is loose from a PO twisting the gripping area back and forth while driving so now it is loose in just that area. Thought about injecting a flexible glue of some kind like rubber cement or even something like Permatex Right Stuff but wasn't sure it would ever cure inside that rubber outer ring. Anybody every try something like that or something else that worked?
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
![]() Join Date: May 2006
Re: Moving grip surface of steering wheel fix?
They have a super glue that specifically bonds to plastics for plastic repair. Look for it in the hardware stores. I've used it and it works very well. I think you could probably drill some small holes in the back of the wheel and inject this super glue product. I think it will work to fix the problem you describe.
1989 K1500 Chev. EC Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit. 2009 Hummer H3T 3.7L 5M (sold) 1997 K2500 Chev. EC 7.4L/ 4L80E (sold) 2018 Dodge Ram 2500 HD R/C |
| Bookmarks |
