Old 08-24-2021, 03:47 PM   #1
1960chevypanel
700R4 decoding help?
Does anyone know where to find the codes for a 700R4? I have two 700R4's and am trying to figure out the differences between them and decide which one I should use. The pad on the right rear corner reads 4YP061C on one, and 5VG353B on the other.
1960chevypanel is offline   Reply With Quote
Old 08-24-2021, 03:58 PM   #2
sick472
sick472's Avatar
Re: 700R4 decoding help?
Those would be '84 and '85 units. See here...
https://mechanicbase.com/transmissio...-transmission/
I just went through sourcing one of these transmissions and have been told by a few tranny folks that the one you want will be newer than an 87 unit...something to do with upgrades that GM made as the years progressed that made them better. I guess the new models would be better, but the 85 model that was in my K20 seemed to do fine until I broke a corner of the tail housing when separating the transfer case. My advice would be to find a newer one of you are building something above stock horsepower or to use beyond daily driver status.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 08-24-2021, 04:04 PM   #3
sick472
sick472's Avatar
You might find this helpful too...
http://shop.ukrtrans.biz/wp-content/...gs/TH700R4.pdf
1972 C10
1985 K20
Old 08-24-2021, 04:30 PM   #4
Just call me Sean
Just call me Sean's Avatar
If it's 2wd the newer ones will have a VSS and metal gear instead of the plastic gear and mechanical drive for the speedometer.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 08-27-2021, 08:42 PM   #5
1960chevypanel
Thanks Sick, I see the year coding but there's no breakdown for the model code (which I think is the two letters after the year). But maybe I'm asking the wrong question—are both of my transmissions identical? I was assuming some difference in performance (gearing, strength) depending on the application (a pickup vs a Camaro for example), but maybe I'm wrong... Are they all built and geared the same way? If so I'll just pick the better condition one. This will be going behind a mildly built small block, not a pavement pounder.
Old 08-27-2021, 09:02 PM   #6
Just call me Sean
The older ones have weaker internal parts.
Old 08-30-2021, 08:36 AM   #7
sick472
sick472's Avatar
According to the PDF I linked...
The 4YP is from a 1984 5.0L "F"-CAR
and the 5VG is from a 1985 4.3L "C"-TRUCK/"G"-VANS (Calif)
My guess is that these transmissions are basically equivalent, key word "guess".
1972 C10
1985 K20
Old 08-30-2021, 07:09 PM   #8
GRADYS Performance
GRADYS Performance's Avatar
Use the 85, It is the 2nd version of the 700R4/4L60 transmission with a 30 Spline input shaft. The 82-84 had a 27 spline input shaft. Internal gear Ratios are the same in all transmissions.
GRADYS Performance is offline   Reply With Quote
Old 09-01-2021, 01:18 PM   #9
1960chevypanel
Sorry man, I must have missed that when I checked the .pdf. Thanks for the help!
Old 09-01-2021, 01:19 PM   #10
1960chevypanel
Cool thanks for the info 👍
