Old 09-27-2021, 04:23 PM   #1
Willys_MB
Willys_MB's Avatar
GMC Headlight Bezels and 3/4 Ton Control Arm Shaft and Leaf Spring Bushings
Buyer pays all shipping and fees
C20 Lower Control Arm Shaft - Moog K6147 - I ended up thinking I lost one of the caps and in the middle of a project I ordered a second one. Then when I moved to a new house, I found it. One cap is painted, was test fitted, then "lost." Never torqued, installed, or used. $15+shipping thread closed
C20 Leaf Spring Bushings - Moog SB319 - I learned (the hard way) that the bolt size changed some time between 1968 and 1971. These bushings were pressed in, but never used. I ended up pressing them out because the bolts I was using were bigger than these bushings. This is a full set for a Dana 60 rear end and I put anti-seize on them before pressing them in. $30+shipping SOLD
GMC Headlight Bezels - I should call this the "lessons learned" sale thread. I bought these later style headlight bezels not knowing they wouldn't fit into the 1967/8 grille. Minimal rust, super clean, no issues except for two small dings. $50+shipping thread closed
Items consolidated into another thread. This thread is closed.
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
