Door gaps.
I've been trying to get the gaps set correct on the door before I weld in the new rocker. How in spec are you door gaps? My doors upper is rubbing inside on the B pillar. I set in new door pins. Do your doors have consistent gaps.
Bottom .25in Sides and top .19in |
Re: Door gaps.
My doors are set with a paint stick, I think right at 3/16"
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
Re: Door gaps.
Make sure your hinges brackets are not wore out, if the door pins where wore out really bad for a long time the bracket of the hinges may be started wear to much. A new striker bolt and adjusting it may need add shimmed or take out some time and bushing for the striker bolt. The hinges need to be adjust to the to front a little gap at front may need shimmed give some room. Do one adjustment at a time move to the next then you will know what it doing. Having a adjusting box end ratcheting wrench is + ** Now after welding your rocker may have to adjust the door bottom as in shims. If your rocker is open from front to back you may have a little play in the bottom side of the B pillar.
Try to get as close as you can after tack welding check door at the B pillar at the bottom may spreading a little because of cut out or rust out. Take your time adjust little bye little think about it as you do it.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
| Bookmarks |
