one inch drop coils
I have a set of 1 inch drop coils in the front of my 65 c10. I now have the engine installed and most of the front clip and the springs hardly moved at all If I stand on the frame and bounce it they seem really stiff. Will they settle at all once I start driving it? I was planning on installing 3 inch drop in the rear but am afraid the rear will be lower than the front
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
Re: one inch drop coils
Drive it a bit and let it settle (if it settles at all), then trim a bit of the front coil spring bit by bit until you get the stance you want. I usually cut the last inch or two off the end of the pigtail.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
Ok thanks
![]() ![]() Join Date: Nov 2012
Most aftermarket spring suppliers sell you a "X Inch Drop" spring. They are guessing since they know nothing about your specific truck. Like if you have a 230 L6/ 3 Spd or an iron 454 V8/Turbo 400. Also they are not able to tell you what the spring rate is. Spring length and spring rate are two entirely different things. Always remember if you shorten a given spring, you are increasing the spring rate.
Here's mine. I did 3" in the back and 1"in the front. The first pic is without modifying the front springs. The second is after I cut about half of the first coil off the front springs. I think it actually lowered the front about 2". Gave the truck a really good look I thought. All the springs were purchased from CPP.
Also the first picture had the 250 6 cylinder 3 speed and the second was with a 283 th350 automatic. I think the 250 is actually heavier but not sure. Hope that all makes sense... |
I buy MOOG 1-ton coils, and just keep lopping inches at a time until it sits perfect.
![]() Join Date: Sep 2006
3in drop spindles and 3in drop springs. Might look funny since the truck is facing up hill and not on flat land.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
| Bookmarks |
