Old 02-02-2022, 03:16 PM   #1
HO455
HO455's Avatar
US Mags Indy wheel fitment
Having searched to no avail as to whether the new classic slotted U.S. Mags Indy U101 wheels will fit a 71-72 disk brake front end.
My Burban has been converted to 5 lug with 71-72 front end components and a rear axle.
I am planning on the 15x8 wheels with 4 inch backspacing.
My current wheels are only 3.5" backspacing
Any help would be appreciated. I am hoping someone can confirm them clearing the brakes so I can order all 4 at once instead of just one to test clearance.
I should have done this post 2 weeks ago as I see the prices have jumped $13 a wheel since then. DHOOO!
https://www.summitracing.com/parts/usm-u10115807340
RIP Bob Parks.
Old 02-02-2022, 07:18 PM   #2
CG
BlahBlahBlah
Re: US Mags Indy wheel fitment
Those will look so good on your burb. I hope they work out for ya.
Old 02-03-2022, 04:15 PM   #3
SCOTI
SCOTI's Avatar
I'm not sure what the concern is regarding the wheels inquired about not working w/the specifically mentioned 71-72 5-lug set-up? I've seen them on Squarebody trucks for sure & they're similar as far as the suspension & brake set-ups :
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-03-2022, 05:22 PM   #4
30772
Fit is perfect on my 72 K20 disc brake front end....if that is any help?
30772 is offline   Reply With Quote
Old 02-03-2022, 07:35 PM   #5
HO455
HO455's Avatar
My concerns are sparked by today's "That's close enough! " manufacturing tolerances. As an example when I replaced my lower control arms with reproduction ones I had to grind about 3/16" off of the end of the control arm to allow the rotors to turn. Photo below.
My current wheels that fit with a 3.5" backspacing, very likely would rub the tie rod with a 4" backspacing. Unfortunately none of the currently available 15" slotted mags come in a 3.5" backspacing.
I was hoping that I might avoid some shipping return hassles by posing the question here first.
Thanks CG!
RIP Bob Parks.
Old 02-03-2022, 07:40 PM   #6
HO455
HO455's Avatar
I wish it was more of an apples to apples comparison. But seeing how good they look on your truck assures me I'm making the right style choice. Thanks.
Great looking truck by the way!
RIP Bob Parks.
Old 02-03-2022, 07:49 PM   #7
57taskforce
All about them K’s
57taskforce's Avatar
I’ve been saving for a set for my K20 for a bit now. They look so good on these trucks.
Love yours!
Tyler
57taskforce is online now   Reply With Quote
Old 02-03-2022, 08:14 PM   #8
SCOTI
SCOTI's Avatar
Thanks CG!
Makes sense.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-03-2022, 09:48 PM   #9
CG
BlahBlahBlah
I think I have a set of five lug and a set of six lug mags put away somewhere with our trucks bolt patterns. But I would rather have a new set.
Old 02-08-2022, 04:08 PM   #10
HO455
HO455's Avatar
I'm feeling the need for new ones too! After the ordeal I had getting one of the current wheels repaired after the wreck, being able to order a new replacement if needed sounds like a great idea.
RIP Bob Parks.
Old 02-21-2022, 08:22 PM   #11
HO455
HO455's Avatar
As a follow up I got the wheels and they fit great.
Even with the back spacing difference there is slightly more room between the tie rod end and the wheels outer edge compared to the old wheels.
Wheel weights need to be placed carefully so the won't contact the brake caliper.
The rear axle hub is a very close fit (Hub centric) and any deformity or build up of rust will prevent the wheel from fitting correctly.
RIP Bob Parks.
Old 02-21-2022, 08:29 PM   #12
CG
BlahBlahBlah
Wow, those look great!
Old 02-22-2022, 12:27 AM   #13
Boog
laying low
Boog's Avatar
It looks good. I'm mostly glad you went with 15". It just looks right!
Boog
Old 02-22-2022, 09:34 PM   #14
HO455
HO455's Avatar
Thanks everyone. I appreciate it.
RIP Bob Parks.
Old 02-23-2022, 02:51 PM   #15
71gmcC15
71gmcC15's Avatar
Do you think 15x10s 4 inch back spacing would fit?
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 02-23-2022, 04:25 PM   #16
HO455
HO455's Avatar
I can take some pictures and get some measurements for you.
My 67 Suburban has the wider 71-72 12 bolt rear end in it. You will need to take that into consideration if you have a different rear end.
RIP Bob Parks.
Old 02-23-2022, 04:29 PM   #17
HO455
HO455's Avatar
I forgot to mention that I found that the price on the wheels through Jegs had not gone up like Summit's had.
If you're on the edge of ordering some best not delay. Summit had raised the price $13 a wheel.
RIP Bob Parks.
