Old 02-16-2022, 05:27 PM   #1
KyFarm
KyFarm's Avatar
Brake pedal spring re-install
Ok, I’m now sure I should have re-installed my brake pedal before the steering column but I didn’t.
I have the pedal re-installed but could really use some pointers on how to get the spring attached to the tab on the firewall.
Seems there should be a tool with a notch in it to hold that spring loop, maybe I need to make one.
I can get a screwdriver in there and push the loop almost into place but no way to have enough hands and room to make it catch.
First post from phone, hopefully it works.
Any help is appreciated
KyFarm is offline   Reply With Quote
Old 02-16-2022, 06:39 PM   #2
leftybass209
leftybass209's Avatar
Re: Brake pedal spring re-install
do you have a set of brake tools? Maybe those can give you slightly more leverage?
I installed mine with the column out so I couldn't give you an objective answer.
leftybass209 is offline   Reply With Quote
Old 02-16-2022, 08:47 PM   #3
kwmech
Easier to pull it down than push it up
Old 02-16-2022, 09:15 PM   #4
HotWheelsFan
HotWheelsFan's Avatar
You can loop a coat hanger or wire around the open loop of the spring and pull on it. Downward...
HotWheelsFan is offline   Reply With Quote
Old 02-16-2022, 09:18 PM   #5
kwmech
Old 02-18-2022, 04:36 PM   #6
KyFarm
KyFarm's Avatar
If anyone ever searches for the same issue, here is what I did.
Took out the main pivot tube at the top of the brake pedal while keeping brake pedal attached to the actuator rod ( rod going through firewall) then I could pivot top of brake pedal towards firewall greatly shortening length needed to stretch spring. Attached spring to firewall then re-installed main pivot tube which then became a wrestling match if it’s own but would have been easier if you have someone to guide it into the drivers side of the fixture it mounts into. I didn’t but eventually got it all together.
Mounted the button and now onto something else.
KyFarm's Build/Need help thread
1969 K-10, Short Step, (383HT/4L70E soon)-NP205
