Old 02-28-2022, 10:06 PM   #1
stepsider
stepsider's Avatar
Brake lights
My brake lights are on when the ignition is on. I just added power brakes. No fluid in master cylinder. Where is the brake switch located ? Do I have to bench bleed the master cylinder and the lines before the lights go off ??
stepsider is offline   Reply With Quote
Old 02-28-2022, 10:42 PM   #2
truckster
truckster's Avatar
Re: Brake lights
The brake switch is behind the brake pad lever. If the brake lights are on, it's probably because the brake pedal is laying down too low. Did you have to adjust the brake actuator rod (the part that goes through the firewall)?
Edit: The brake lights shouldn't be routed through the ignition switch. They should come on any time the brake is depressed, whether the ignition is on or not.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 02-28-2022, 10:54 PM   #3
Peanut74
Re: Brake lights
X2 truckster's response.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 03-01-2022, 09:37 AM   #4
BigBird05
Re: Brake lights
Well y'll beet me to it.
BigBird05 is offline   Reply With Quote
Old 03-01-2022, 12:31 PM   #5
stepsider
stepsider's Avatar
Question Re: Brake lights
Well I put the tumbler in the ignition And and the taillights are off. I don't know if that was the problem. I still can't find the brake light switch or the wires that you use to connect to the switch.
Old 03-01-2022, 12:38 PM   #6
kwmech
Re: Brake lights
Under the dash, follow the brake pedal arm up, then look for a switch with white and orange wires going to it
