Old 03-11-2022, 01:23 PM   #1
6600DURAMAX
6600DURAMAX's Avatar
Rolled rear pinion fluid level 14 bolt
For my K5 build I have rolled the rear pinion up and need to determine how high I should fill the fluid ? Typically you would just fill to the top of side plug "fill hole" but with it rolled afraid that will leave the pinion dry.... don't want to put too much in however either ....
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
