Old 03-12-2022, 01:40 PM   #1
stepsider
stepsider's Avatar
Question Brake line problem
Adding power brakes to my 72 C10. Got the booster and the master mounted on the fire wall and found out that the smaller of the two lines from the chassis is two short. Solution, Find a line that came off a truck with power brakes or buy a line and bend and fit . I'm talking connection to the proportioning valve under the master cylinder. Am I on the right tract ?
stepsider is offline   Reply With Quote
Old 03-12-2022, 03:33 PM   #2
Accelo
Accelo's Avatar
Re: Brake line problem
You will find the short lines difficult to bend. You have to put the flairs and nuts on it first or you have no room to add the double flairs. I would check with inline tube maybe they can provide them.
This is all I could find.
https://www.inlinetube.com/products/sctb72mc2
They are out of stock on a lot if items right now.
I would call them.
I know Frankk's Pick um up trucks sells a lot of conversions. Maybe call Frank? 360956-7170 PST.
Edit;
Kev2808
Yes, you were correct I mentioned the wrong line.
I agree bending one is the cheapest and best option. Especially if you already have the tools. Getting a good double flair isn't all that easy.
The higher end hydraulic make it easier though. If you are lucky you will be able to purchase lines the right length even if you have to combine them using a coupler.
Accelo is offline   Reply With Quote
Old 03-13-2022, 08:53 AM   #3
kev2809
low n' slo
kev2809's Avatar
i think he means the longer lines coming from the truck side, not the really short ones going to the master from the prop valve. .if you looking for just 1 line I would buy one and bend it to fit. if it will still be short....get the longest one u can get pre made and cut it to fit...then flare the other end with the right fitting.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 03-13-2022, 12:28 PM   #4
pjmoreland
pjmoreland's Avatar
If you straighten out some of the bends in the original line, it might reach. It did for me when I added power brakes to my '68. The line routing is different in '72, so that might be a problem
pjmoreland is offline   Reply With Quote
Old 03-13-2022, 01:53 PM   #5
jimijam00
This stuff bends like a wet noodle.
jimijam00 is offline   Reply With Quote
Old 03-13-2022, 02:52 PM   #6
kev2809
low n' slo
kev2809's Avatar
^^^^ thats what i used when i re did my brake lines recently. can bend that stuff by hand
-_--_--_ _________
