Old 03-16-2022, 10:42 PM   #1
MDFarms
Seat spring help please.
Anyone point me towards a source for the 2 upper long seat springs on a deluxe seat?
These ride on top the big coil spring and attach at each end. These rode higher up along ends of foam where it's cut out.
MDFarms is offline   Reply With Quote
Old 03-17-2022, 12:06 AM   #2
franken
Re: Seat spring help please.
I did an internet search and didn't see the square style, but any upholstery shop will probably sell/give you a section of the sort of sine wave style that might work.
I walked into a shop and asked to buy some hog rings and they just grabbed a handful and gave them to me.
franken is online now   Reply With Quote
Old 03-18-2022, 08:23 PM   #3
hooverfish
hooverfish's Avatar
LMC Trucks has 'end spring repair' piece, item #6 in drawing.
You will need two, one for each end of the seat, fixes the sagging spring on the end of the seat, especially drivers side.
Try to save and re-use the barrel clips when you remove the old/broken spring.
https://www.lmctruck.com/1967-72-che...eat-components
Edit: also, I dont think that coil spring in your picture is OEM, believe it has been added.
Larry
84 Chevy SWB, "Roy", dark blue OG paint, 5.7 LS1, 4L60, Vintage Air, 96k miles.
"It's a sorry man who can't find his wife a good job"
hooverfish is offline   Reply With Quote
Old 03-18-2022, 08:46 PM   #4
MDFarms
I have no clue but do have to saybthe coil spring looks to he correct but then again I dont know.
Old 03-18-2022, 10:56 PM   #5
Grumpy old man
Grumpy old man's Avatar
The round coil spring doesn't belong in there it's someones attempt at repairing the broken springs , The seat you have is a full foam base and the broken edge springs aren't reproduced , I have both types of seat frames in the garage that are bare and I'll get some pictures tomorrow and show the difference between them and what you need to repair your seat .
There are a couple pictures in this thread that show the differences between the seat types but I'll get some better pictures .
https://67-72chevytrucks.com/vboard/...d.php?t=601807
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 03-19-2022, 02:35 PM   #6
Grumpy old man
I'll post more pictures later today , The easiest way to repair your broken seat springs is to bend new ones yourself using Music wire spring steel . it's a lot easier than many may think and you can use your broken one as a pattern .
https://www.amazon.com/PRECISION-MET...s_id=310355011
Old 03-19-2022, 02:46 PM   #7
Grumpy old man
You can just use a pair of pliers to apply the spring clips .
https://www.clipsandfasteners.com/up...ware-s/825.htm
Old 03-19-2022, 04:40 PM   #8
cericd
cericd's Avatar
Hey Grumpy, what are those tools used to bend the music wire. Thanks for posting those pics.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 03-19-2022, 05:49 PM   #9
Grumpy old man
Small tubing bender from harbor freight .
https://www.harborfreight.com/1-8-ei...der-94571.html
