Headers
Bagged 72 c10 sbc 327 with 4 spd manual t10 and dropped spindles need advice on headers that tuck
Re: Headers
Budget build headers for sbc 72 c10 drop spindles with t10 4 spd manual and air bags
Re: Headers
I thought guys were using the Chevelle mid-length headers?
Re: Headers
On that small motor, shorties will do fine.
![]() Join Date: Jul 2000
Re: Headers
I used full-length Patriot #H8048 on an 82 C10 and they tucked up great. Much better than Hooker or Hedman. 1-5/8" primaries, 3" collector.
I see where the same P/N is supposed to fit 69-91 2WD trucks. https://pertronixbrands.com/products...31797134327844 My 82 C10:
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Re: Headers
I'm using the Summit 1 1/2" tube headers on my '71. I only have the 307, so small primaries are perfect for me. These also come in coated, and Stainless.
https://www.summitracing.com/parts/s...ckup/year/1971 |
Re: Headers
If you have the OEM clutch linkage, not sure the mid length Chevelle headers will work. Anybody verify that?
Headers suck on a 2 wheel drive truck as they hang too low. If I was building a truck for the street (I know yours is already together…) I would run the V8 in the 6 cylinder position and use 4x4 headers which don’t hang near as low, routing the pipes above the trans crossmember and not below then routing through the trailing arm crossmember rather than underneath. And C3 Corvette headers are possibly the same as the 4x4 headers. With that in mind, the 2 1/2” Corvette manifolds are always a good choice. Just takes a GOOD muffler guy to make the connections.
#8 | |
Thanks for all the replies it has helped me narrow it down
Posted via Mobile Device |
Re: Headers
A couple more things to consider: Header tube wall thickness is 14, 16, or 18 gauge. Also, flange thickness can be 1/4", 5/16", or 3/8". The minimum for me has always been 16 gauge tubes and 5/16" flanges.
Some of the higher priced models, like Hedman's Elite series, will have 3/8" flanges and 14 gauge tubes. But they are very expensive, and the set I had many years ago on my 69 C10 2WD didn't fit well. Turns out their "test mule" must have been a 67-68 truck or a 4WD truck with the engine mounted a couple inches rearwards. A guy at Hedman later told me they either modified those or introduced a new P/N for 69-72. That was almost 20 years ago, so I don't remember!
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 03-23-2022 at 10:56 AM. |
Re: Headers
The 3/4 length headers don't clear clutch linkage is correct. That's great info on using 4x4 headers with V8 mounted in 6cyl position. I know the full-length 4x4 headers tuck nicely.
