Old 04-08-2022, 09:18 PM   #1
powell72
powell72's Avatar
My solution to Wheel Vintiques Series 62’s
So I recently purchased a set of Wheel Vintiques series 62’s from Summit for my 74. 15x6’s and 15x8’s, I’ve ran them before on my 67-72’s, so no big deal right? They show up, I paint them, get my tires mounted, go to put them on...the rears don’t fit. So naturally I come here and search and find out there’s fitment issues with the Squares with the bigger rear drums. Swapping to the smaller brakes wasn’t an option out of pride because my shoes and drums are brand new. So after some measuring and research, here's what I came up with.
I needed a 1/2” spacer to get the drums to clear the backside of the windows on the wheels. My lug studs were too short to work with a spacer so I would need to replace them. I couldn’t seem to find a longer stud with the same diameter knurl so I went hunting. I also didn’t want a stud so long I needed to pull the axles to install (just resealed the diff and put fresh fluid in).
I came up with these lug studs, that I believe fit a Mercury Mountaineer. Dorman 610-514. Still 1/2-20 thread. Here it is next to the stocker.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 04-08-2022, 09:20 PM   #2
powell72
powell72's Avatar
Re: My solution to Wheel Vintiques Series 62’s
It even has a “clipped” side to help it clear the bearing housing when you put it in.
Chris
Old 04-08-2022, 09:21 PM   #3
powell72
powell72's Avatar
Stock lug stud knurl diameter-
Chris
Old 04-08-2022, 09:22 PM   #4
powell72
powell72's Avatar
New stud diameter-
Chris
Old 04-08-2022, 09:24 PM   #5
powell72
powell72's Avatar
After using a 35/64” drill bit to open the axle flange stud holes, they go right in with the axles in place.
I bought a Bosch drill bit off Amazon for $13. Using my drill on low speed with plenty of cutting oil the bit held up like a champ and cut the last hole just as quick as the first.
Chris
Old 04-08-2022, 09:25 PM   #6
powell72
powell72's Avatar
The right tool for the job always helps.
Chris
Old 04-08-2022, 09:27 PM   #7
powell72
powell72's Avatar
Here’s the wheel spacer I used. A hub centric spacer from Billet Specialties. $47 a piece, but not the place to skimp.
Chris
Old 04-08-2022, 09:29 PM   #8
powell72
powell72's Avatar
Here’s a mock-up showing the clearance I have now. That’s a feeler gauge, the only thing I could find that would sneak in there, with plenty of wiggle room, I was able to rock the feeler gauge side to side.
Chris
Old 04-08-2022, 09:30 PM   #9
powell72
powell72's Avatar
All finished up, just hand tight, more threads are exposed after torquing.
Chris
Old 04-08-2022, 09:31 PM   #10
powell72
powell72's Avatar
All in I spent $160 between Summit and Amazon. That includes buying the drill bit and having to pay shipping from Summit since I was just under $100 on my order.
Chris
Old 04-08-2022, 09:32 PM   #11
powell72
powell72's Avatar
One more.
Chris
Old 04-08-2022, 10:07 PM   #12
Warrens69GMC
Warrens69GMC's Avatar
Good tip!
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 04-08-2022, 10:13 PM   #13
Mathew21
Mathew21's Avatar
Cool Thanks for sharing!
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 04-08-2022, 11:23 PM   #14
Great little write-up, Chris. Nice truck. It's amazing Wheel Vintiques didn't do their homework with these 62 series wheels, since the 5 on 5s would be made primarily for C10s
Old 04-08-2022, 11:31 PM   #15
powell72
powell72's Avatar
Thanks Tim, hoping I can offer a different alternative to a brake swap.
I agree with you, seems like they could have done a little more R&D on them.
Chris
Old 04-09-2022, 08:50 AM   #16
S10Fan
Old Heap Driver
The wheels look great, love steelies and dog dish caps.
Dorman is a great source for lots of items but especially wheel studs.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 04-10-2022, 11:44 PM   #17
ltdmstr
ltdmstr's Avatar
I have a set of these wheels on order with the rears being 15x10 w/5.0 BS. So, does that mean I can expect the same problem? I don't think spacers are going to be a viable option for 10" wide rims with 295 tires.
ltdmstr is offline   Reply With Quote
Old 04-11-2022, 08:46 AM   #18
SCOTI
SCOTI's Avatar
What back-spacing was used? I recall 4" as their standard on 8" wheels.
I would agree there should be a disclaimer on the website but it's possible they're not aware of the issue since most C10's don't have the HD drums. The info should be shared w/them that they don't fit over the HD drum set-ups beyond a certain back-space dimension.
They fit the standard brake packages fine which is what the majority of C10's have. For use on HD drum packages, the wheels beyond 3.5" of BS are not a direct fit.
I can't see any company re-inventing the hub/center of a wheel to accommodate a select few possible purchases. Order the BS @ 3.5" ($25 fee) & there shouldn't be an issue.
What rear brake set-up: Standard rear drums or the HD drums? They won't clear the HD drums. Probably will for the standard duty set-up. Do a quick test fit before you mount the tires would be my suggestion in case things don't work/fit as desired.
Set-up looks good Chris!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-11-2022, 09:45 AM   #19
ltdmstr
ltdmstr's Avatar
I just got the truck a couple weeks ago. So, I'll have to check which drums are on there. And the wheels are on order. Not sure when those will show up. The 5" BS on the 15x10s is a custom order (4.5" BS is standard). So, I'm probably stuck with them either way. Sure hope they fit.
Old 04-11-2022, 10:22 AM   #20
SCOTI
SCOTI's Avatar
Worst case.... You purchase standard brake parts if you have the HD set-up or swap w/someone that has standard brakes but wants the HD parts. The hardest thing to source is the HD backing plates. If you have the HD brakes, getting standard used backing plates is much easier from a wrecking yard or online forum like this one.
Also.... Those 295's are fairly short for the rear of a truck @ <27 (26.6"). What's the plan for the fronts?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-11-2022, 10:53 AM   #21
ltdmstr
ltdmstr's Avatar
I'm going to use 245s on the front which are same diameter. Tires a little small, but should be fine with a mild drop. Guy I bought it from had the thing slammed pretty good and was running 295/70/15s on the back, which barely fit and were almost impossible to get off without messing up the fender/trim. Fronts he had 255/70/15 with spacers. But the inside wall was still all chewed up. Whole thing was a mess. It's going down to the frame for a complete redo. It's a '74 shortbed with 454/TH400. Going back to stock 2-tone color scheme which was Rosedale Red/Frost and white steelies with T/A Radials.
Old 04-11-2022, 11:27 AM   #22
SCOTI
SCOTI's Avatar
225/70's on 8's & 275/60's on 10"s is my usual suggestion for the height w/very similar section width vs wheel width. Your F/R heights & section widths being incrementally similar works well visually w/the right drop. Post up pics when you get them.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-11-2022, 11:49 AM   #23
ltdmstr
ltdmstr's Avatar
Eventually. Just starting the teardown and then sending the body parts off for stripping and e-coat. Should have the chassis back together over the summer. Then it just depends on how long it takes for bodywork and paint. Btw, the truck in my avatar photo (although obviously not a square) has 275/60s rear and 255/60s front.
Old 04-11-2022, 07:18 PM   #24
Loco83
Loco83's Avatar
This is my 83 with the 245 and 295's,15x8 and 10's. no rub and 4/5 drop.
Loco83 is online now   Reply With Quote
Old 04-12-2022, 03:45 AM   #25
powell72
powell72's Avatar
First of all, gotta say I was hoping you’d chime in on this thread and share some knowledge!
They are 4 1/4” BS. I think that’s the standard on them. All the 62’s I’ve ran have been 4 1/4” BS on 15x6, 15x7, and 15x8’s.
The method I used here would only work for widths up to 8” I would assume without a custom backspace.
The issue with these wheels and the HD drums is the outside mounting surface of the drum is recessed in about a 1/4” deeper than the lip on the outside of the drum, so the lip on the outside edge of the drum hits the backside of the four window openings on the perimeter of the wheels before the inner wheel mounting face touches the drums outer mounting surface. It’s been so long since I’ve seen the back of a GM steel wheel I’d love to see a pic to compare how GM’s windows in the wheels are rolled in compared to Wheel Vintiques.
Chris
