Old 04-19-2022, 12:53 PM   #1
BigElittleg64
BigElittleg64's Avatar
Driver side floor indention
I have been looking at the floor pan of my truck and i see that there is an indention on the driver side rear by the door and not one on the passenger side. Is there a reason for this?
BigElittleg64 is offline   Reply With Quote
Old 04-19-2022, 11:57 PM   #2
AcampoDave
AcampoDave's Avatar
Re: Driver side floor indention
If i remember correctly my '61 had a cover with a couple of screws over that indent and underneath was an electeical plug possibly for the dome light or gas gauge. I put a seat belt retrsctor in there on my '64 and '66
AcampoDave is offline   Reply With Quote
Old 04-20-2022, 04:40 PM   #3
66C10LB
I'm in the same decision making process, whether or not to use this indent for the seat belt retractor, or to put the retractor just to the rear of that (in the original seat belt bolt position at the rear cab support flange).
66C10LB is offline   Reply With Quote
Old 04-20-2022, 10:49 PM   #4
val1gonzales
Here's a pic that shows it held some wiring.
val1gonzales is offline   Reply With Quote
Old 04-22-2022, 04:26 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
Page 128 the assembly manual.
Also this shows the cover and screws:
Old 04-25-2022, 09:07 AM   #6
BigElittleg64
Thanks for the info, I would have never thought that is was for a switch and wires. Nice to know.
Old 04-26-2022, 03:30 PM   #7
61K10
61K10's Avatar
my 61 has it with a cover. the main rear tail light harness goes through it. The changed it in later years maybe63 or 64? rear harness went out through the fire wall if i remember right.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-27-2022, 08:18 AM   #8
bsarts
bsarts's Avatar
I used that spot to mount a battery disconnect switch for anti-theft and battery protection.
bsarts is offline   Reply With Quote
Old 04-27-2022, 09:54 AM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
That is interesting. I never knew about that. Anyone have a picture of the cover and the wiring? Just curious to see it.
66 C20 Service Truck:
