Old 04-25-2022, 08:20 PM   #1
Joe P
66 K20 Frame Tail Length
My 66 K20 eight foot bed Fleetside is missing the tail ends of the frame rails, and I will need to extend to the correct length in order to properly mount the bed. How long should they be? Photos show the right rear rail as it sits. Measurements were taken from the back of the cross piece.
Joe P is offline   Reply With Quote
Old 04-26-2022, 08:34 PM   #2
72cs20
Re: 66 K20 Frame Tail Length
Right behind your rear spring frame bracket there is a small hole in the side of the frame rail. On my 66 K20 it is 11 1/4 inches from the middle of that hole to the end of the frame.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 04-26-2022, 10:59 PM   #3
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Some of these might help:
http://67-72chevytrucks.com/vboard/s...d.php?t=325736
66 C20 Service Truck:
Old 04-27-2022, 08:46 AM   #4
Joe P
Thank you, I appreciate your time and the information very much. This is helpful.
Old 04-27-2022, 08:53 AM   #5
Joe P
Originally Posted by LostMy65 View Post
Thank you! Appreciate the references!
Old 04-28-2022, 01:35 PM   #6
MT65
Took these today , 65 k-20…….at least these are close, just finishing a c-10, the rear xmember was 5/8 out of square, all the rest good…go figure…
MT65 is offline   Reply With Quote
Old 04-28-2022, 02:38 PM   #7
LostMy65
LostMy65's Avatar
What do you mean the rear cross member was out of square by 5/8 of an inch? There is a rear cross member that is supposed to be out of square with the frame.
Old 04-28-2022, 04:59 PM   #8
Joe P
Thank you for the photos very much. They are very helpful. Thankfully, my truck is square even though it had a hard life and was really rusty. I replaced the rear cross rail (with the help of another member on this list who made parts for me) because it was so thin. Thank you again!
Old 04-28-2022, 08:15 PM   #9
MT65
Maybe you could school me on why that would be….
Old 04-28-2022, 09:01 PM   #10
LostMy65
LostMy65's Avatar
I don't know if I'd 'school you'.
I'll see if I can find the thread.
That's been asked, regarding that one cross member being at a slight angle.
I'll see if I can find it. But it's not a error in assembly.
Sorry if my tone sounded like I was trying to set you straight. No pun intended.
Old 04-28-2022, 09:12 PM   #11
LostMy65
LostMy65's Avatar
Found it - You'll see it the same on many leaf spring trucks of our generation.
Here is a post:
Originally Posted by Shane View Post
triangulation is correct ... if you will notice, it's angle runs opposite the angle of the Panhard bar.
Here is a pic:
Old 04-28-2022, 09:17 PM   #12
MT65
Found it.
Here is a post:
Here is a pic:
The one on mine was not that one , but the extreme rear one.
I measured for a fuel tank, of course I measured the long side, built the tank, proceeded to attempt to install…..drilled out the rivets and moved it back an inch and square….
Old 04-28-2022, 09:18 PM   #13
MT65
No worries, just my way of saying teach me….
