Old 12-31-2003, 09:53 PM   #1
rage'nrat638
rage'nrat638's Avatar
***omg...94 Amp Alt. On Your Trucks***
THANKS....racedvl for hooking me up on this baby.....
got the alt. conversion kit from frank/ PICKMUP
put this baby on....WOW......................
LET THERE BE LIGHT
TURNED EVERY THING ON....
HEATER FULL BLAST
HEAD LIGHT'S ON BRIGHT
WIPER'S FULL BLAST
FLASHERS ON
STEREO ON HARD ROCK
the alt gauge don't move
my wiper's run faster
the heater blow's harder
the dash light's are brighter
my alt. gauge used to pulse with just the blinker on
NO MORE FLICKERING LIGHTS HERE
YOU HAVE GOT TO DO THIS
rage'nrat638 is offline   Reply With Quote
Old 12-31-2003, 09:58 PM   #2
rage'nrat638
IT'S A 84 CAMERO 94 AMPER'S ALT
HERE'S THE ALT. JUMPER
Old 12-31-2003, 10:00 PM   #3
rage'nrat638
HERE'S THE REGULATOR JUMPER
Old 12-31-2003, 10:11 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I got a 110 from summit it rock's!!!!!!! Stock alternator's are really dim ......Everthing seem's to work better with more power!!!
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-31-2003, 10:20 PM   #5
krue
Designated A-hole!
krue's Avatar
That's next on my list!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-31-2003, 10:31 PM   #6
dinnut
dinnut's Avatar
question: did you have to do any special wiring or did you use an alternator conversion kit? i should get one of these if that not what i have... lol i dont know since i didnt put the alternator on... i think mine is bad anyway. how much did the alternator cost? i have the conversion kit... i have a int. regulated... do you think that is what i have? but it doesnt work all the time... that one looks nice. hmm...
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-31-2003, 10:36 PM   #7
Chevy Punk
How much do you want for your old one? The rebuilt one we put on my truck this summer is making weird noises. I may not need it but I'll keep it in mind
Chevy Punk is offline   Reply With Quote
Old 12-31-2003, 10:37 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
i have a int. regulated... do you think that is what i have? WHAT??I must be out in left field??? Too many beer's maybe What do you mean dinnut???
MEMBER #6377
Project "7DEUCE"
Old 12-31-2003, 10:41 PM   #9
dinnut
dinnut's Avatar
im confused... im not that intelligent when it comes to alternators... help me! is this the upgraded unit from the camaro?
geez man you love to make fun of me when i dont know somethng!
70 longbed
496/th400/Ford 9"
Old 12-31-2003, 10:42 PM   #10
skokie
skokie's Avatar
2nd that krue. Conversion kit already ordered.
skokie is offline   Reply With Quote
Old 12-31-2003, 10:44 PM   #11
FRENCHBLUE72
PROJECT 7DEUCE
Dinnut is your alternator internally regulated or do you still have the black box on the core support??? If it;s internally regulated it will not use the box on the core support.. Need any other help we or I would be glad to answer any ??? Dont wanna jack this thread either ... Sorry mark..
MEMBER #6377
Project "7DEUCE"
Old 12-31-2003, 10:51 PM   #12
rage'nrat638
stock trucks are external regulated....
the stock alt..put out about 60 amps tops....if your lucky
about 20-30 amps at idle........
chevy punk....that new rebuilt alt...20.00 plus the ride...stocker
this new internal regulated alt. is from a 84 camero w/305
94 amp alt....106 amp. max output.....IT ROCKS
THE CONVERSION KIT I GOT FROM FRANK/ PICKMUP
CHEAP.............
JUST PLUG IT IN AND GO...NO WIRING INVOLVED ...
MAN YOU SHOULD SEE THE WIPERS MOVE ON THE DRY WINDOW
IT'S LIKE A DIFFERENT TRUCK.....
THE 6 MILLON DOLLAR MAN TRUCK
Old 12-31-2003, 11:08 PM   #13
skokie
skokie's Avatar
Old 12-31-2003, 11:24 PM   #14
miket
miket's Avatar
Originally posted by rage'nrat638
GOT A NEW REBUILT STOCKER...CHEAP IF YOU NEED ONE
For not a whole lot of money you can rebuild that into a 105 amp single wire.
Here is where you can buy the parts
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 12-31-2003, 11:42 PM   #15
krue
Designated A-hole!
krue's Avatar
Do you have to have the conversion kit, or can you replace the plug on existing harness and jumper out ext reg?
www.daveramsey.com
Old 12-31-2003, 11:56 PM   #16
rage'nrat638
no you don't have to have the conversion kit....
just get a new end from the help section at the auto parts store
and make two 4" female spade end wire's and jumper the plug on the external regulator
the outside wire goes to the third one and the forth one goes to the second one....I THINK
RACEDVL KNOWS FOR SURE ON THE JUMPERS
Old 01-01-2004, 12:10 AM   #17
Leinie
My Blazer has already been converted to single wire, internal regulator. Can I just put in an 84 Camaro 94 amp alt and go?
Leinie is offline   Reply With Quote
Old 01-01-2004, 12:20 AM   #18
rage'nrat638
this alt. use's the stock wiring.....yes you can if somebody has not cut the stock wiring out...
the one wire alt.has one wire running to the battery....
i did not want the one wire because then my alt.gauge would not work...and on my 85 the battery light would stay on
Old 01-01-2004, 12:53 AM   #19
dinnut
dinnut's Avatar
eh.... i do have an internally regulated alternator. BUT FOR SOME REASON the black box on the firewall appears to still be plugged in. so im running int and ext. regulated alternators
what i was asking if yall usually use this alternator he is talk about to convert to internally regulated... and thought yall might poke a guess at whether or not i have a high ampeage alternator like this one...
i am going to be installing a new (used) front lights harness and properly install the conversion kit like he has. i already have one.
70 longbed
496/th400/Ford 9"
Old 01-01-2004, 01:53 AM   #20
TRUCKSRUS
if your running a internal regulated alt. then your external reg. box should not be plugged in
my guess would be it's not internal.....
they made all kinds of outputs on these alts.
take yours and have it tested to find out what it is
TRUCKSRUS is offline   Reply With Quote
Old 01-01-2004, 02:53 AM   #21
rage'nrat638
better get that regulator deal figured out dinnit....
that could be your electrical problems
Old 01-01-2004, 03:30 AM   #22
dinnut
dinnut's Avatar
yeah i probably should get it all figured out. right now im getting another underdash harness and front lights harness so i can put those on the truck i bought a new engine harness and an alternator conversion kit... and im thinking ill buy an alternator like yours ragenrat638. your definitely into your 69 now huh? youre getting the sickness? haha thats cool...
my plug on my alternator is the style of plug for an int. regulated alternator...
70 longbed
496/th400/Ford 9"
Old 01-01-2004, 03:51 AM   #23
bmg
bmg's Avatar
i agree dinnut, you must use one or the other. I had both running on mine and both the alt and the ext reg went bad. so i just ended up with a 110amp alt internal reg. and bypassed the one on the rad. core.
bmg is offline   Reply With Quote
Old 01-01-2004, 03:59 AM   #24
dinnut
dinnut's Avatar
i didnt know it could kill the alternator... im going to be changing the harness soon and while im doing that ill correct all these mistakes the stupid mechanics made b4 me made on this truck ( and believe there are alot)
70 longbed
496/th400/Ford 9"
Old 01-01-2004, 01:13 PM   #25
TRUCKSRUS
fix that alt first
