| View Poll Results: Which direction to take? | |||
| Replace damaged harnesses with good, used GM ones |
7 | 58.33% |
| Get an aftermarket kit to rewire the entire truck |
5 | 41.67% |
| Voters: 12. You may not vote on this poll | |||
![]() ![]() ![]() Join Date: Jan 2018
Chewed up wiring harness, what would you do?
I have a dilemma, and would like to get some input on the situation.
The 81 I'm getting has a ton of wires chewed through under the hood, and I need to make it right. Everything in the cab seems fine as I didn't see any rats nest material in the cab. I don't know what the wires look like under the bed and such, but I wouldn't be surprised if some have been chewed. Goals for the truck is to keep it mostly stock. Maybe I'll swap to a 4 barrel and throw a cam in the 305. Definitely thinking about lowering it some. I don't have plans or a desire right now to LS swap. If I do decide to engine swap, it'll most likely stay sbc powered because I like them ![]() So what would y'all do?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 350, Saginaw 4 speed "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson Last edited by cwcarpenter98; 05-24-2022 at 11:16 PM. |
| Bookmarks |
