Old 06-26-2022, 06:42 PM   #1
buffydores
buffydores's Avatar
Why Do the Squares Wiggle in the mid 60s mph?
Everybody I talk to observes the same thing. Is it just frame resonance?
Old 06-26-2022, 09:07 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: Why Do the Squares Wiggle in the mid 60s mph?
I’ve owned 8 different squares and I’ve never experienced this. Can you explain further?
Old 06-26-2022, 09:21 PM   #3
I've never experienced this wiggle. I've had 1/2t and 1t 2wds as well as K/5, 3/4t and 1t 4wds including Suburban. What do you and the others own that wiggles?
Old 06-26-2022, 09:57 PM   #4
kwmech
Tighten bolts and get a good front end alignment?
Old 06-26-2022, 10:03 PM   #5
mongocanfly
mongocanfly's Avatar
Never heard of it either
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-26-2022, 10:18 PM   #6
Getter-Done
Getter-Done's Avatar
I have owned several.
I have not experienced this.
The early bird gets the worm,
85 Chevy K-20
Old 06-26-2022, 10:42 PM   #7
Warrens69GMC
Warrens69GMC's Avatar
My 1978 Longbed is smooth. Never had this happen.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 06-27-2022, 12:51 AM   #8
Pontiac1976
Pontiac1976's Avatar
Looking at your profile pic what size tires are you running are they over sized 4x4 off road tires. If they are that may be because your running to much side wall, that may be where some of it coming from. The bigger the side wall & the faster you go the more the side wall will grow at speeds and give you some wiggle.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 06-27-2022, 04:46 AM   #9
buffydores
buffydores's Avatar
It's nothing like death wobble. It's just certain speeds that have harmonic vibrations. Talking to quite a few folks, they experience it at between 63-67 mph. You couldn't align, balance, check or brand new anything more on this rig.
Old 06-27-2022, 06:42 AM   #10
cadillac_al
It's almost impossible to get a perfect tire balance; even on my Cadillacs. My 76 GMC has a tire vibration between 57-60 mph. It smooths out before and after those speeds.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 06-27-2022, 08:28 AM   #11
Dead Parrot
My 75 C10 does it on occasion. The vibration has survived several sets of tires, a new set of rear bearings, new u-joints, a new exhaust system, and a major fix-up of the front end.
When mine does it, it cycles between nothing and a very noticeable vibration over a couple of seconds. Tends to be at higher speeds, above 65.
Guessing it is a combo of exhaust drone interacting with tire speeds and drive line vibrations.
Dead Parrot is offline   Reply With Quote
Old 06-27-2022, 08:30 AM   #12
Rich84
Rich84's Avatar
47-52 MPH for me. More of a up and down wobble.
Rich84 is offline   Reply With Quote
Old 06-27-2022, 09:11 AM   #13
buffydores
buffydores's Avatar
Yes. This is the experience. It's smooth at all other speeds. It's done it with multiple sets of tires. Even though I have a well balanced CV driveshaft with a properly shimmed pinion angle, I still feel like some of its there, but the rest I suspect is resonance in the frame.
Old 06-27-2022, 09:43 AM   #14
Keith Seymore
Keith Seymore's Avatar
Mine doesn't.
Rock solid as fast as you want to go.
As a former full vehicle development engineer, driveline development engineer and brake development enginer - I've never noticed it on any of the thousands (?) of squares I've driven.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-27-2022, 12:07 PM   #15
buffydores
buffydores's Avatar
And to clarify, it feels like a driveshaft or wheel balance deal.
Old 06-27-2022, 02:24 PM   #16
Keith Seymore
We did have a few "inherent" wobbles that got built in, but more like during the GMT400 and GMT800 days.
The longer trucks could get into a frame "beaming" mode but that was usually vertical (up/down, rather than crosscar).
I also recall a particular extended cab configuration that would wobble right off the line. Just two or three kicks, as a result of the 2 piece driveline configuration, and then clear up.
That was one you weren't going to fix without some "invention".
K
1979-1986
1986 - 2019
Old 06-27-2022, 05:56 PM   #17
Honest Bob
Honest Bob's Avatar
Both my squares have a slight vibration around the 65mph mark, although I've always chalked it up to never having had an alignment or balance done on either.
Honest Bob is offline   Reply With Quote
Old 06-27-2022, 07:53 PM   #18
72c20customcamper
72c20customcamper's Avatar
Keith you explained what I experienced with my 77 Suburban . Truck would go up and down we used to call it porpoising. My 87 burban only did it when towing but my 77 would do it regularly.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 06-27-2022, 09:34 PM   #19
buffydores
buffydores's Avatar
Originally Posted by Keith Seymore View Post
Mine doesn't.
K
Keith: You seem comfortable in this space. What would you look at? I've had the wheel tire setup balanced on a fancy machine. Driveshafts built by Tom Woods. No difference before or after.
Old 06-27-2022, 09:53 PM   #20
bigdaddy4x4
bigdaddy4x4's Avatar
all of the m1008 that i have owned and my 79 k30 will sway a little when acceleration you can feel it go right and let off the pedal a little and it will go back straight i think its caused by the torque from running the 4,56 gears
bigdaddy4x4 is offline   Reply With Quote
Old 06-28-2022, 09:33 PM   #21
Eyegore
What Hump?
Eyegore's Avatar
& rplace lea spring bushings and ball joints and any other warn out suspension parts
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 06-29-2022, 01:08 PM   #22
kwmech
One thing I forgot to mention is that these frames be it 2 or 4x had a tendency to crack around the steering box mount. Check the bolts for tight and look carefully for cracks
Old 06-29-2022, 11:12 PM   #23
Getter-Done
kwmech
I think you just Nailed this Issue.
Op needs to check the frame for cracks and add one of these.
Name:  steering brace.jpg
85 Chevy K-20
