Old 07-25-2022, 06:48 PM   #1
kens65fb
Trailing Arm Crossmember Question???
I bought a new trailing arm crossmember with openings for exhaust pipes.
My question is should I use the upper holes, or lower holes.
I installed the trailing arms in the lower hole, and it seems to have raised my truck, which I have gone through a lot of effort and expense to lower.
Anyone have an opinion on which set of holes to use.
The box is not installed on the frame yet, so now is the time to adjust.
kens65fb is offline   Reply With Quote
Old 07-25-2022, 07:28 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Trailing Arm Crossmember Question???
It kind of depends on what you plan on doing or how you intend to drive your truck. Using the upper holes moves the instant center forward and up for better traction in racing applications since our trucks tend to have a lot of chassis weight bias to the front.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 07-25-2022, 07:54 PM   #3
kens65fb
No racing for me, them days have long passed !!!
Old 07-25-2022, 08:17 PM   #4
vin63
vin63's Avatar
Then I would just go by pinion and angle and ride height.
Old 07-25-2022, 08:20 PM   #5
kens65fb
Old 07-26-2022, 11:42 AM   #6
MikeN
MikeN's Avatar
Agree with Ken - will also say that the lowest hole will be closest to the stock location.
MikeN is offline   Reply With Quote
