Old 07-30-2022, 06:30 PM   #1
Mister319
1960 clutch pedal problem
The shaft on my clutch pedal has the rectangular bar on the end instead of the splines, and it has broken it seems like my only option is to replace the whole clutch brake pedal assembly, or weld the old one, has anyone had success in welding that bar back on?
Mister319 is offline   Reply With Quote
Old 07-30-2022, 10:45 PM   #2
62bagger
62bagger's Avatar
Re: 1960 clutch pedal problem
Do you have a picture of what you are describing?
62bagger is offline   Reply With Quote
Old 07-31-2022, 02:28 AM   #3
Mister319
The splined shaft is bigger in dia it will not work without changing the whole assembly.
Old 07-31-2022, 03:11 PM   #4
Grounded63
As long as you vee groove the joint out, so you get good penatration. It would probably be fine, as long as that is a weldable steel. That darker brown finish, ( if that's the natural finish ) rather than Grey. Makes it look very similar to 1144 sp, which doesn't have good welding properties.
It looks like a pretty simple part, at least on that one end. You might look into having a local machinist making you a duplicate of it. As one option.
Grounded63 is online now   Reply With Quote
Old 10-21-2022, 12:58 AM   #5
slepysal
slepysal's Avatar
did you get it sorted out?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 10-21-2022, 01:08 AM   #6
Mister319
Yes I did thank you, I had it welded and it is doing fine.I determined that what caused it to break is that the pushrod that goes into the clutch side of the master cylinder,had somehow turned itself on it's threads and became to long causing it to bottom out in the master cylinder.
Old 10-21-2022, 01:36 AM   #7
slepysal
slepysal's Avatar
Good to hear! I think mine is broken nice to know it's weldable Thanks
