Old 08-25-2022, 08:31 PM   #1
jzorn94
Gas tank question
I have a 61 C10 longbed fleetside. I am going to install a gas tank under the bed. I was thinking of using a a 31 gallon 73-81 suburban gas tank. I know I will need to relocate one of the crossmembers to make it fit. My question is, will the 63-66 suburban sending unit fit the 73-81 tank, so I have the correct ohm sending unit for my gauges?
jzorn94 is offline   Reply With Quote
Old 08-25-2022, 11:18 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Gas tank question
I think the older tank is a 5 bolt pattern and the newer is 6 bolt so...
Old 08-26-2022, 07:55 AM   #3
jzorn94
I was looking at the tanks and sending units from classicparts. They seem to be the style that use a locking ring instead of bolts. Maybe they are using a generic photo for the product.
Old 08-26-2022, 07:30 PM   #4
AcampoDave
AcampoDave's Avatar
That tank holds lot of gas which is nice, but won't it hang pretty low?
AcampoDave is offline   Reply With Quote
Old 08-26-2022, 07:56 PM   #5
jzorn94
Probably for most people it would hang too low. But I am leaving my truck at stock height, and I don't care if the tank is visible or not. I think I am going to go with a mustang style tank from Tanks Inc instead, because of the sending unit bolt pattern issues. It will cost more than Classic Parts, but I will be able to do what I wanted.
Old 09-02-2022, 09:28 PM   #6
jzorn94
I decided to go with a suburban 31 gallon tank and modify it with parts from Tanks Inc. I did a mock-up of a suburban 40 gallon tank 35"x29"13" with the rear cross-member moved to the very end of the frame. The tank fits, but is too close to the relocated tracking bar mount.
