Old 10-22-2022, 05:27 PM   #1
jabborabbo
jabborabbo's Avatar
Bearing cap eroding?
Size:  92.6 KBCan the axle cap be installed wrong? I took off in my truck a while back and heard rattling in the front right wheel - took the hubcap off and the cap had come off, and there were tiny metal specks visible in the bearing grease - both bearings seem fine…the cap had specks inside it:
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense
jabborabbo is offline   Reply With Quote
Old 10-22-2022, 05:35 PM   #2
v30crewcab
v30crewcab's Avatar
Re: Bearing cap eroding?
better look closer at your bearings. sounds like one is getting eaten up.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 10-22-2022, 05:49 PM   #3
jabborabbo
jabborabbo's Avatar
That was my first thought - but there aren’t any metal specks in either of them….
And there wasn’t any squealing….
Old 10-22-2022, 07:23 PM   #4
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
I think V30 is correct. I'd be for taking it apart for a real close inspection.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 10-23-2022, 12:05 AM   #5
mr48chev
mr48chev's Avatar
Make sure that someone didn't trim the cotter key wrong and that it wasn't rubbing in the cap.
Still inspecting and repacking the wheel bearings is just periodic maintenance and if you do it in far less miles than you planned it is just an hour of your time and a little bit of wheel bearing grease.
I'd pull the bearings out, wipe them off with a shop towel and inspect them and properly pack them and reinstall them. Absolutely do not wash them with solvent unless you fully intend to replace them. The solvent never gets out of the bearing and won't allow the grease to stick to the bearing surfaces right. I was taught that 60 years ago as an automechanics student in high school and have followed it and do not have wheel bearing trouble that doesn't have a different cause. In all the years I was doing brakes for a living I never had a car come back with bad wheel bearing after I serviced the bearings.
My ongoing truck projects:
Old 10-23-2022, 09:39 AM   #6
72c20customcamper
72c20customcamper's Avatar
Never heard that said about cleaning bearings .
In 50 plus years never had a problem cleaning bearings in lacquer thinner let them dry and repack .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-23-2022, 11:40 AM   #7
jabborabbo
jabborabbo's Avatar
This makes perfect sense based on my original info regarding the location of the shavings, the present condition of the bearings, PLUS the fact that the cap was somehow teased off the axle!
I’ve already bought replacement bearings just in case, and I did wash the old ones in solvent to inspect them.
Thank you Sir!!!!
Old 10-23-2022, 12:59 PM   #8
kwmech
I have heard of it...if you leave the solvent. I actually use K1 kerosene in my solvent tank and I'll wash them out if needed for inspection. If they are smooth and free of foreign material, I'll rinse them with some brake clean or thinner and repack. Never had a problem
Old 10-24-2022, 07:54 PM   #9
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I'm surprised nobody commented on the bone dry cap!? If that cap is that dry with dry particulate on it, then I'd suspect them bearings are needing grease in a bad way! I agree with cleaning the bearings and liberally repack them! Get them caps involved and smear some grease on them too! "Heavens to Murgatroyd!" PS. I use mineral spirits in my parts washer, the key is using compressed air to thoroughly dry whatever your cleaning. Might have to try that #1 Kerosene if it's cheaper than mineral spirits...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 10-25-2022, 11:07 AM   #10
jabborabbo
jabborabbo's Avatar
I wiped off the grease before I took the picture :-)
Old 10-25-2022, 12:56 PM   #11
72c20customcamper
Just don’t spin the bearings with the air . My cousin was doing this because he liked the spin up sound it made ,he wasn’t the sharpest tool in the shed . Before I could say anything the bearing let loose . He got a couple of bruises on his face and took out four overhead fluorescent bulbs.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 10-25-2022, 01:12 PM   #12
Steeveedee
Steeveedee's Avatar
My ex-brother-in-law liked to do that spinning business, too. I told him that it's a good way to ruin a bearing. When I worked as a mechanic. we had a tool that forced new grease in and the old grease out. At home, they get cleaned in mineral spirits, left to dry and hand-packed with grease.
~Steven
Simi Valley, CA
