Old 04-01-2023, 10:11 PM   #1
tll74
"Junkyard Dog"
tll74's Avatar
Tire size Q's
Hi guy's, I'm looking for tire size recommendations for my 72 C10 build. It's a 72 C10 LWB. It will have 3-4 lower kit. I'm thinking a 255/60R15 rear and 245/60R15 front. Or maybe 245/60R15 all the way around. I'm using 15x8 factory rallies. Any pics of such and suggestions would be great. Thanks
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline   Reply With Quote
Old 04-01-2023, 10:27 PM   #2
streetstar
streetstar's Avatar
Re: Tire size Q's
I think long beds look better low and level,
But that said , 255 to 245 won’t rake it out much
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 04-01-2023, 10:55 PM   #3
HO455
HO455's Avatar
Re: Tire size Q's
Have you looked at this thread?
http://67-72chevytrucks.com/vboard/s...d.php?t=703601
I'm running 275 60 15s on the rear with 245 60 15s on the front.
RIP Bob Parks.
Old 04-04-2023, 10:02 AM   #4
SCOTI
SCOTI's Avatar
Re: Tire size Q's
245/60-15's = ~26.57" tall.
255/60-15's = ~27.04" tall.
Both are shorter than an original size range (27.7 - 28.8).
Clearance-wise you'd be good.
Visually, it comes down to personal preferences.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-04-2023, 10:16 AM   #5
Extended Power
Extended Power's Avatar
Re: Tire size Q's
What “look” are you going for?
That plays a huge factor in choosing tires.
Since you are a lowered, I am assuming that you like the sporty look, over the utilitarian look.
I have my truck lowered 3” in the front, 3 1/2-4” in the back.
I have run as wide as 325/50r15 in the rear, and currently have 295/59r15 in the rear. 245/60r15 fronts both times.
To me, my truck still has to drop down in the rear, as it has too much rake to it.
And to me, the fender wells are still not filled enough.
I have new tires being mounted on my new wheels today, 20 x 10 front, 20 x 12 rear.
Front tires are 275/35r20, rears are 29/15r20.
No pictures yet.
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
