Old 04-10-2023, 03:52 AM   #1
Belsh
Junior Member
5 or 6 lug preference
I'm going to order a front and back disk brake conversion kit for my 1970C10 which is currently a 6 lug on aftermarket 20 inch rims. Other than having to change my wheels are there any reasons to go to 5 lug over 6 or is it simply a case of personal preference? Thanks
Belsh is offline   Reply With Quote
Old 04-10-2023, 04:05 AM   #2
Belsh
Junior Member
Re: 5 or 6 lug preference
Sorry guys I should have searched this before asking, found lots of info in previous threads. If I could work out how to delete it I would
Old 04-10-2023, 07:15 AM   #3
ghackett1
68 C10 Longbed
ghackett1's Avatar
No worries, since u asked I kept my (6) lugs on my 68. I purchased some 70 rally’s and was able to find them in 6 lug so I kept it there. If I switch to disc I will reconsider although you can get 6 lug rotors that will fit. It’s all personal choice and money.
ghackett1 is offline   Reply With Quote
Old 04-10-2023, 01:50 PM   #4
cericd
cericd's Avatar
One thing to keep in mind is that there are many styles of aftermarket wheels that aren't available in 6 lug. If you plan to change wheels I'd go with a 5 lug setup to open up your aftermarket wheel options. Also, the 6 lug rotors are generally a bit more expensive than 5 lug parts from the same company. However, if you plan to keep your current 6 lug rims you'd be better off using the 6 lug rotors.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 04-10-2023, 04:27 PM   #5
I don't know why, but if I had a 67/68 I'd stay with 6-lug but would be inclined to go 5-lug with a 69/70. If I already had wheels I wanted to stay with I'd stay with the lug pattern I had. My '67 project is on a '71 chassis that already has a 4/5 drop with 5-lugs, of course, plus I already have 8" 5-lug steelies. So that's an exception to my rule, even. I'd rather have 6-lug but I'm not changing what I already have
Old 04-10-2023, 05:11 PM   #6
BRL
BRL's Avatar
I currently have 6-lug drums both front and rear, pretty sure they're original of course.
I would like to have 5-lug with disks up front.
There just seems to be so much more custom wheel choices with 5-lugs from what I've seen.
BRL is offline   Reply With Quote
Old 04-10-2023, 05:58 PM   #7
No reason to change except for different wheels. 6 lugs are very common in truck world now days, so there are plenty of choices, especially if you like the big wheels like your 20s. For 15s and 17s there us a much greater wheel selection in 5 lug.
Old 04-11-2023, 12:50 AM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have a '68 C/10 [6-lug], a '71 K/1500 [6-lug], a '67 K/10 and a '72 K/5. They all take 6 lugs on 5.5'' spacing.
I'd be stupid to convert to 5 lug, just to run some chronologically incorrect and [imho] garish looking rims.
