alternater bracket
Need help will stock 2005 5.3 alternater and power steering bracket fit in 1949 chevy 3100 truck with mustang 2 front end ?
![]() Join Date: Jul 2007
Re: alternater bracket
Stock in what donor chassis? I'm thinking that some of them put the alternator and maybe other accessories too far out to the side and too low.
1949 chevy truck 3100 with mustang 2 front end from Chassis Engineering.
a pic says a thousand words. there is a how to thread if you are unsure
No one here can answer that question. GM had a different alternator and PS bracket for every model the 5.3 went in. High mount, low mount, left or right... Why don't you just bolt your brackets on and see what happens? Alternative is to make your own, very easy to do.
cool, an ogre smiley Ogre's 58 Truk buildhow to put your truck year and build thread into your signature shop air compressor timer |
The crossmember isn't going to be an issue, Clearance with the inner fenders and space between the block and the radiator are going to be the issues. That is with just about any engine except a 216 or 235 with the 54 waterpump setup on it though.
There are a lot of variables like the height and set back of your engine. Generally the Camaro or Corvette set ups allow the most clearance for your radiator/ fan to fit. You can also use a Holley set up like this http://67-72chevytrucks.com/vboard/s...605484&page=45
I have an '04 GTO engine in my 51, it sits low so I had to relocate the alternator. It's also as tight as it can be against the firewall, so I barely have room for a fan.
1951 Truck, LS1/4L60 1964 Suburban, current project |
Power steering pump and alternater bracket fit on 1949 chevy truck with 5.3 engine may have to modify inner fender well . Thanks for all the input.
mount the bracket and shoot us a picture.
RUBBER DOWN AND HIT THE ROAD!!!1940 Ford Dlx Coupe 1969 Mach1 |
| Bookmarks |
