Old 08-04-2023, 01:54 AM   #1
Nevada51
Rear window rubber - small window vs large window
So I ordered a rear window rubber for my '64 small window C-10 but was given a large window rubber instead. Normally you'd send it back but I bought it about two years ago, so that's not an option. My question is: can I use the large rubber and trim it to size, or do I need to buy a small window rubber? Doesn't look like there's any corners on it, so I thought it might be ok to just trim.
If it is ok to trim it, does anyone have a good measurement of how big it should be?
Appreciate your thoughts on this.
Nevada51 is offline   Reply With Quote
Old 08-04-2023, 02:57 AM   #2
Braunschweiger
Re: Rear window rubber - small window vs large window
Since the small window rubber is also cut to length,
you should also be able to use the large window rubber.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is online now   Reply With Quote
Old 08-07-2023, 12:36 AM   #3
Nevada51
Good to know, thanks for the reply. Looks like I'll be cutting it up!
If anyone's got a rubber handy that they could measure that'd be helpful, otherwise I'll measure twice and cut away.
Old 08-07-2023, 01:39 AM   #4
SkinnyG
SkinnyG's Avatar
Put the seal in the cab first, and have the "join" at the bottom. Make it so that the seal overlaps a couple inches on both ends, then stuff the "couple inches too long" seal in so the ends but firmly against each other.
I wonder if you could get two small seals out of one large seal.
This was my install video:
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 08-07-2023, 03:16 AM   #5
Nevada51
HOW TO: Install Back Glass - YouTube
Thanks - great video; you make it look very straight forward. The suction cup handle looks really useful for the install.
