Old 09-24-2023, 01:28 PM   #1
Extended Power
Extended Power's Avatar
Can the AC service ports be moved?
There is no way to get access to both of the service ports if I install them right off the compressor.
Before I get the hoses crimped, is it OK to move the service port up onto the firewall? It would have excellent accessibility.
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 09-24-2023, 01:39 PM   #2
weq92f
weq92f's Avatar
Re: Can the AC service ports be moved?
Just thinking this through I believe the location of the high pressure port shouldn’t matter. It’s gonna give you pressure readings wherever it lives. It’s the suction side that concerns me. It should probably live somewhere between the evaporator and compressor.
Hth,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 09-24-2023, 03:20 PM   #3
howzzzit
howzzzit's Avatar
They don't look like too bad of a location. If your having trouble connecting to the high side there are 90 degree adapters for your manifold hose. I never use the high side anyway. You might be causing yourself a lot of work???
howzzzit is offline   Reply With Quote
Old 09-24-2023, 07:43 PM   #4
Extended Power
The way they are in the pictures, is the way I want to run them.
I have both, the 90* fittings, and the 135*? fittings...these are the best position I can get.
