Old 10-07-2023, 07:31 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Question about American AutoWire Headlight Relay Kit
I bought the American Autowire Headlight relay upgrade kit ( # 500403 ) and wonder if anyone else has installed one of these where did u mount the relays.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 10-07-2023, 08:19 PM   #2
truckster
truckster's Avatar
Re: Question about American AutoWire Headlight Relay Kit
I built my own but I mounted the relays next to the battery.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is online now   Reply With Quote
Old 10-07-2023, 08:21 PM   #3
Warrens69GMC
Warrens69GMC's Avatar
Mounted the one from LMC, relays next to battery.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 10-07-2023, 08:39 PM   #4
Already Gone
Thats what I was thinking, by the battery.
Old 10-08-2023, 01:06 AM   #5
PDXk5
PDXk5's Avatar
I did the same. Here is a pic of where I mounted my relays
PDXk5 is offline   Reply With Quote
Old 10-08-2023, 06:58 AM   #6
I used different kit, but mounted the relays and fues near battery
Old 10-08-2023, 10:07 AM   #7
PbFut
If you are still using the factory battery meter connecting the power source of the headlight to the battery or fuse link block will trick the meter into a charging display. The source of power for the lights needs to be on the other end of the shunt wire. Look at your meter with headlights on and alternator not turning. You should display a discharge. If you have connected to the battery side of the shunt, you will show a charging state rendering the meter worthless when headlights are on.
PbFut is offline   Reply With Quote
Old 05-07-2025, 10:34 PM   #8
Already Gone
I'm getting ready to do the install and I have the Amercan Autowire Voltmeter # 51087 on the truck already. https://americanautowire.com/product...1&_ss=e&_v=1.0
Old 05-08-2025, 01:09 AM   #9
Rust_never_sleeps
Rust_never_sleeps's Avatar
I installed self-resetting breakers after reading a few threads on this site about headlight kits…….they also went on the inner fender ;-)
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 05-08-2025, 11:17 AM   #10
RichardJ
I have mine on the driver side fender.
The wires from the dimmer switch-to-headlights pass by, under the lip of the fender.
All connections are made with male/female connectors that match up so that the relays can be disconnected and the original wires can be plugged back into each other as they were originally.
Other than the relay pigtails, the only length of wire added was the 12V source.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 05-08-2025, 12:16 PM   #11
Already Gone
Yes good idea, I have one of those to install too.
Old 05-09-2025, 08:25 PM   #12
G-749
Active Member
71 C 50 292 4sp vacuum operated 2sp rear axle. Userd the LMC headlight relay kit . Long stretch from headlight to headlight, didn't have enough length to mount relay on inner fenders so I had to put them forward of the radiator support and behind the grill , can't see them at all unless you are looking for them. Huge improvement for all the lights . Wasn't sure would fit C 50. Good luck on all your projects.
70 C 20 Longhorn PS , PDB, Dealer installed AC, 700 R4, Dual battery, original TAX 350 motor, 3rd owner truck.
71 C 50 292 4sp 2sp vacuum operated rear end 8 x 12 flat bed.
22.5 Goodyear radial$ n Wheels Now rim$
86 Grand Wagoneer " Saggy Waggy " Jeep = Just Empty Every Pocket $$$ currently in another shop
G-749 is offline   Reply With Quote
