67 POL Rack and Pinion Steering Shaft
Having trouble getting steering shaft linkage from stock column to POL rack and pinion on a 67 with stock 250. Notching the frame and cutting the DD on the column are next on the table I suppose to try and reduce angles. The close coupled joints on the rack are my latest attempt. I've tried equal length shafts to get joints apart and same issue. Anyone get one of these in without notching frame?
| Bookmarks |
