Very sorry about asking this...
I’ve watched you tube, and read all kinds of reviews, but no one seems to have the full answer, so I will ask here:
572 BBC, Lemons 2 1/8” headers to 3” collectors. Going to run 3” mandrel bent pipe, and exiting in front of the rear tires. I don’t want to run to the back of the truck, as I have leaf suspension with Cal-Tracs, and a tank between the rails. (Don’t want any extra heat in the fuel) I also don’t want turn downs, as my back alley is dirt/gravel, and anything dumping down will just get the truck dusty. I have seen Jason VanNatta run 2 1/2” mufflers, but I heard his new Venom truck, and it sounds like it may “rap”. I do not want a rap/turkey shooter/brappy exhaust. I want a deep mechanical sounding idle that will showcase the solid roller cam, and brute power of the big block. What round, or oval 3” muffler will fit just after the crossmember where the steady bearing is, and give the sound I am looking for without killing the performance when going wide open?
"If it ain't broken, fix it 'till it is!" |
| Bookmarks |
