10-17-2023, 04:50 PM | #1 |
Currently Blazerless
Steering Wheel
This is a very high quality steering wheel from a 1987 Monaco motor home that used a GM tilt like the one in these trucks. It's leather wrapped and it's 18" , that makes it 1" bigger than a stock wheel. The hub adapter bolts to the steering shaft just like a GM wheel and then the wheel is bolted to the hub with 9 Allen head bolts. This uses a nice self contained horn button and spring. I'm sure the Monaco emblem could be switched for a Chevy bowtie or GMC emblem if some kind. 125.00 shipped
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C Last edited by BLAZERMAN; 10-17-2023 at 04:57 PM. |
10-19-2023, 07:10 AM | #2 |
One of the First
Re: Steering Wheel
Is the backside clean - no abrasions??
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
10-19-2023, 03:41 PM | #3 |
Re: Steering Wheel
Yes backside is nice, adapter hub could use repainting. The wheel could use a good cleaning.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
10-20-2023, 07:57 AM | #4 |
One of the First
Re: Steering Wheel
I would like to get this from you, install it my 70-c30. But, with all the parts in the pictures, it will bolt up to a 70 steering column head (n0n-tilt) and have a working horn button? I really don't need a $$ mistake. Inflation baby!
10-20-2023, 10:44 AM | #5 |
Re: Steering Wheel
David, Yes it will bolt right up to your 70 non tilt column. I'll include the horn contact with the wheel, you shouldn't need anything else to make it work. I know what you mean about "inflation", it's getting crazy!
10-20-2023, 11:15 AM | #6 |
One of the First
Re: Steering Wheel
Sounds good, Ill take it, sent you a PM.
