![]() Join Date: Jul 2011
Windshield wiper motor
What would cause the wiper motor in my '68 to operate in the wash mode (push button) only? Is that more common to be a switch, or motor issue?
![]() Join Date: Apr 2016
Re: Windshield wiper motor
What are you observing that makes you ask this question? I don't see how the stock washer can work at all unless the wipers are moving, because the washer pump relies on the wiper motor movement to actually pump.
#3 | |
#4 | |
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
My assumption would be that it's the switch but that's just a guess
67 C10 283 T5 swapped longbed fleetside = wife's daily driver(divorced) 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD(Sold) 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck(divorced) 73 El Camino SS 454 4 speed my first big block Can you tell we are fans of longbed fleetsides & 67s Chris |
I think it is likely the switch is having problems. You would have to do some testing with a test light or multimeter to tell for sure. Here is a thread about testing. http://67-72chevytrucks.com/vboard/s...d.php?t=413551
The back of the switch is swaged to hold it together. You can probably test it when removed from the truck with an ohm meter. It has 3 lugs on it, each of which should ground to the switch case when pushed or turned to certain positions. In low speed 2 of the lugs should conduct to the case, in high speed 1 of the lugs should conduct to case, and in how or high speed pushing the button should conduct the 3rd lug to ground. Take the switch apart and clean it up with WD-40 or DEOXIT D5. Then put it back together. |
![]() Join Date: Feb 2010
Yep, +1 on all that.
-- '67 Chevy Stepside 250 Inline 6 Megasquirt Fuel Injection T5 5 speed conversion Ferric Oxide impregnation throughout |
![]() Join Date: Jun 2022
wiring diagram here: https://67-72chevytrucks.com/vboard/...d.php?t=185856
I'm afraid when talking about the wiper motor circuit specifically, most of the MANY diagrams in that thread have incorrect wiring in that area. You have to go specifically to post #344 of that thread. There may be other versions in that thread having the correct wiring for wiper motor, but most are incorrect. Unfortunately it would take a huge effort to clean out all the incorrect info in that thread. Here is a link that lands on post #344:
https://67-72chevytrucks.com/vboard/...27#post9186727 Last edited by dmjlambert; 10-18-2023 at 08:00 PM. |
#9 | ||
Replaced the wiper switch. buttoned it all up. No wipers. Back to the same drill with the washer mode pushed in only. I came inside, I'll revisit that tomorrow. Thanks for the tips, although I didn't pull it apart to make it work. It seems like it was more something to do with the spade connections on the back of it than internal contacts. I have De-Oxit and Fader lube if I need to take it apart. I'm an old electronics nut too. Quote:
Does your dash have new paint, particularly where the switch mounts in the hole? It's another possible thing, and pressing on the switch makes it contact ground.
#11 | |
![]() No fresh paint. I'll figger it out tomorrow. Got to be something simple. I'm just proud the motor is operating. One less thing to deal with. |
#12 | |
#13 |
interesting, I didn't see either the switch or motor connected to ground on the wiring diagram :shrug:
#14 |
Only18B at the cluster connector is grounded. I don't see the switch referenced in the schematic to see a ground, just the connector. Are you thinking these wiper switches aren't supposed to be grounded?
#15 | |
The Older Generation
If the wiper switch isn't grounded the wiper will not work.... LockDoc
#16 | |
I've got my wipers all squared away now. ![]() Thanks Leon. |
#17 | |
No problem. I just read it differently.... ![]() LockDoc
#18 | |
I'm just annoyed I can't see it on the diagram |
#19 |
![]() Join Date: Dec 1999
I have the exact same problem. Anyone have a theory about why it only works for the push? Does it somehow get ground that way, but not the normal way.
And then I found this thread: https://www.67-72chevytrucks.com/vbo...d.php?t=695112 Post 15 Vette Vette is a treasure.... I had tried a new switch and that didn't fix my problem. So I thought! I took the new switch back out and put the old one in. After reading this thread, I decided I would clean the paint off to make sure the switch was grounding and check with a meter to make sure it was grounded. It was. But still not wipers. Dug up the new switch and reinstalled. Yay, I have wipers now! |
#20 | ||
Until I made sure the switch was set in the pocket just right it wouldn't ground to the dash to get the wiper motor to run in wiper mode. Someone had already been in mine before so I couldn't tell exactly how the grounding spot was supposed to look, but there was a bare spot at the flat edge at the top of the hole that made the ground. It has been a long time since I've worked on anything like this, but it almost looks like when the switch hole was punched, the flat edge was slightly raised (extruded) to guarantee a good ground there. Someone else might know more about that. As far as the wiper working when the washer button is depressed, I believe that ground we see in the schematic at the cluster connection is why it works when the button is held in. |
#21 | |
Further exacerbating the problem was, my truck is 1968 and I changed to later style dash bezel and extended the wiper wires over to where the choke was, so the hole is not the same shape as the real wiper switch hole. |
#22 | |
| Bookmarks |
