Old 01-10-2004, 08:05 PM   #1
LGCC10
Junior Member
What size lowering block?
Looking for some info on lowering blocks.What detemines the size of the rear lowering block? In the front I have 21/2 drop spindles and will be installing airbags. The rear has a large
c-notch and will also have airbags.What size lowering block do you use?
Thanks for the help,
Pete
LGCC10 is offline   Reply With Quote
Old 01-16-2004, 10:56 AM   #2
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I would say 2 or 3". Deflate the bags and see how much clearance you have. There are a lot of guys on here who have fabbed up there own out of bar stock steel material. I wish I could just throw a set of blocks on mine. My 72 has rear leafs, sucks, sucks.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 01-16-2004, 10:58 AM   #3
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
The lowering block goes on top of the truck arm, but below the axle tube. You probably already knew that though. Check out www.djmsuspension.com Good Luck!!
Old 01-16-2004, 06:48 PM   #4
fastbagged68
fastbagged68's Avatar
I'm running bill turner 4 inch weld on blocks. I'm going to be laying frame on 20's with about a 29 inch tall tire!
fastbagged68 is offline   Reply With Quote
